oil usage with deisel engines
Submitted: Wednesday, Feb 02, 2011 at 19:50
carlj
I have just returned from Proserpine to get my grandchildren out of the cyclones way we did approx 2300kms in about 29hrs and 2 drivers.Have just washed the car and checked the oil found the oil down approx 500ml I know it was ok before we left is this excessive usage?
Reply By: Member - Serendipity(WA) - Wednesday, Feb 02, 2011 at 19:54
Just some more info
What sort of car are you driving?
Even still diesel engines do use oil as a natural process. I believe toyota has an allowance of up to 1 litre per 10,000km. It also depends on how hard you are driving and the load you are towing.
443942
Reply By: blue one - Wednesday, Feb 02, 2011 at 20:36
Is it a Nissan? If so what model & year?
443945
Follow Up By: carlj - Wednesday, Feb 02, 2011 at 20:54
Patrol 3lt 2000 180000 on the clock but had Nissan replace
the block and pistons at 141000 as it burnt holes in 3 and 4.
716030
Follow Up By: blue one - Thursday, Feb 03, 2011 at 18:49
Sounds sus I would have it looked at. Is it blowing blue smoke at all?
716131
Follow Up By: carlj - Thursday, Feb 03, 2011 at 19:45
run beautiful and no smoke
716144
Reply By: Member - John & Lil - Wednesday, Feb 02, 2011 at 21:17
I agree it may appear excessive, but a lot of manufacturers will tell you that falls into their tolerence. A pint of oil in the old money for what seems a pretty intensive drive probably isn't over the top. Keeping an eye on it back at normal driving will give you a better idea. Speaking to Toyota Landcruiser 200 owners today and they would be happy if that was only how much oil their truck used. It only has 20,000klms on it.
443953
Reply By: Member - Graham H (QLD) - Wednesday, Feb 02, 2011 at 22:03
If you have been pottering around town for some time before doing this trip it could just be burn off of condensates from idling along.
Lots of vehicles do that when run hard after a long time of just mucking about.
Other than that is it due for an oil change.
I had a Nissan Bluebird diesel that used no oil for first 4000k and then used a pint a 1000 till it was changed.
443964
Follow Up By: carlj - Thursday, Feb 03, 2011 at 19:44
had it serviced at 180000 it is now 184000.Doesn't use oil around town but on long runs usually around 4 to 6 thousand it will drop approx 1lt this is loaded with a roof rack or towing a 1.75ton van
716143
Reply By: Member - Duncs - Wednesday, Feb 02, 2011 at 22:55
My 4.2 Litre GU never needs a top up between changes. It is just coming up to 200,000km on the clock.
Duncs
443983
Follow Up By: Michael ( Moss Vale NSW) - Thursday, Feb 03, 2011 at 20:34
Same with my 4.2 TDI,, no oil useage and 312,000 ks on the clock... Michael
| Patrol 4.2TDi 2003
Somewhere you want to explore ? There is no time like the present.Member My Profile My Blog Send Message |
716155
Reply By: Gossy - Thursday, Feb 03, 2011 at 08:57
I have a 2.8td GQ and it never uses oil. After every trip or 5000km's (which ever comes first) I replace the oil. The level is still exactly the same (though rather black :) ).
Something definately isn't right IMHO.
444005
Follow Up By: Brian Purdue - Thursday, Feb 03, 2011 at 09:54
The handbook for my Mercedes states on page 78 that oil consumption "...depends on the way of driving: max. 1 L/1000 km." I find that stop-start driving in the metro area uses more oil than running at a constant speed in the country where the consumption drops to practically nil.
I think the critiea is that oil consumption shows that lubrication of the cylinders is effective.
716086
Reply By: Gossy - Thursday, Feb 03, 2011 at 10:24
makes sense. My GQ is only used for trips away on the open road.
444016
