VMS 430
Submitted: Wednesday, Feb 02, 2011 at 09:52
ThreadID: 84061 Views:1919 Replies:2 FollowUps:0
I have a 430 VMS with memory map and Ozi explorer on it and street Nav.
I have had a lot of trouble with M. Maps. Some days it saves the way points & tracks then other days it will not. The other day I found everything gone that had been saved.
Ozi seems to work alright but it is not as clear as M M. The colour lay out on MM makes it very easy to see. Ozi also seems a bit fuzzy.
They told me to down load an older version of MM which they said is better.
No luck. Why bring out a new version if it is worse than the older one anyway.
I was wandering if anyone else has had trouble with their VMS and if they have had satisfactory help from VMS for a replacement or a fix
Lachie
Reply By: Member - Alan H (QLD) - Wednesday, Feb 02, 2011 at 12:21
GPSOZ
You might try the vms forum at gpsoz.
AnswerID: 443916
Reply By: Member - reggy 2 (VIC) - Thursday, Feb 03, 2011 at 00:14
HI
There is a VMS sight where u can get answers to that I have been on it
myself my problem was transfering I printed a copy of the fix (SAVING ISSUE IN MEMORY MAP FIX) go Q/A hope this helps cheers reggy2
AnswerID: 443992
