inflatable fun boat
Submitted: Thursday, Jan 27, 2011 at 11:21
Member - IdahOz
Any one recommend a brand or model of inflatable boat? Intended use would be to paddle around on lake or estuary when camping with kids to add to the fun. Our set up does not have room for a tinnie or kayak. Not looking for anything to go whitewater or out to sea on!! Thanks
Reply By: Member - Alastair D (NSW) - Thursday, Jan 27, 2011 at 12:14
We bought a simple light duty Sevylor inflatable for much the same reason as you. It needs to be treated carefully but did the job. The more robust ones were much more expensive.
443191
Follow Up By: Member - IdahOz - Thursday, Jan 27, 2011 at 12:32
yeah i am looking at their 360 fishing boat, thanks
715264
Follow Up By: Madfisher - Thursday, Jan 27, 2011 at 12:48
We have a 360m and use it for river fishing. You can get an extra tough skin to go over the bottom and up the sides.
Well worth it. Only weakness is the oar set up. The oarlock tends to come out, and also get an extra oar as they can come apart just when you need it.
Cheers Pete
715266
Reply By: Sigmund - Thursday, Jan 27, 2011 at 12:25
Same here: a Sevylor canoe. Made of PVC so it can be punctured by sharp rocks etc. Waterproof fabric tape is a quick fix, pending a patch and glue.
Had
mine for years.
443192
Reply By: Member - John and Val - Thursday, Jan 27, 2011 at 12:28
We have a Sevylor although we haven't used it much. It has I think 5 separate buoyancy compartments. Takes maybe 15mins to set it up including putting on the electric motor.
Have a look on eBay, not so much to buy but to see what is available and likely prices.
Val
| J and V
- Albert Einstein
443193
seems to be the consensus so far, thanks
715265
Reply By: Member - Min (NSW) - Thursday, Jan 27, 2011 at 15:56
Hi IdahOz,
We have a Sevylor tandem sit-on-top. It's like a big surfboard with clip-on seats which have pockets on the backs for drinks, lunch, fishing gear etc. We have had lots of fun with it and our grandkids love mucking around with it.
It is quite tough with two air chambers. It is paddled with double paddles. It is not for white water. It weighs 15kg and packs into a mesh bag roughly 75x50x20.
Have used it in rivers and lakes all over Australia.
Min
443206
Reply By: Member - Min (NSW) - Thursday, Jan 27, 2011 at 15:59
Hi IdahOz,
Min
443207
Follow Up By: Member - Min (NSW) - Thursday, Jan 27, 2011 at 16:01
Sorry about that. Clicked twice, EO isn't behaving after being down for a while.
Min
715272
Reply By: Member - Josh- Thursday, Jan 27, 2011 at 16:16
Reply By: Member - Vince M (NSW) - Thursday, Jan 27, 2011 at 21:23
if you what a long lasting strong Inflatable then the Achilles brand is the top model made from hypalon material most (92%) of surf clubs craft are Achilles most pro rafters use Achilles but be aware that a model with a fitted transom will not be much good in white water & a strap on transom model will not be much chop in flat water or bays etc so pick wisely, do your
home work & don,t be fooled by sales talk
when it comes to inflatables if you buy
well (it wont be cheap) & you will have it for years & years with no problem (i still use a Avon & Achilles that i purchased in 1982) one has lived half it life outside & both have been used 100s of times including 8 trips down the
Franklin)
good luck
Vince
443248
