Waeco CF50 - Not Cooling
Submitted: Tuesday, Jan 25, 2011 at 20:37
Member - Aaron L (NSW)
Hi All. I have a 7 year old Weaco CF50 been perfect until this week :) . It has stopped cooling I can hear the compressor start but it cuts out after 30secs or so. I have tried it on 12v and 240v - same issue. However if I run it on the emergency bypass - it works and froze a 2ltr bottle of water in normal time.
ANY ideas for further diagnosis before I attempt to pull it apart. Also it has error light when on normal fridge setting!
cheers Aaron
Reply By: Member - Aaron L (NSW) - Tuesday, Jan 25, 2011 at 20:38
Should of said has NO error light flashing !!!
443022
Reply By: AlbyNSW - Tuesday, Jan 25, 2011 at 22:12
Sounds like an electronic fault if it is working in bypass mode
Mine did a similar thing and they replaced the keypad circuit board, it turned out the problem was caused by moisture ingress corroding the circuit board from me cleaning with too muchwater around the keypad area
Can't help you with repair cost as
mine was done as a warranty job luckily
443031
Reply By: Kiwi100 - Wednesday, Jan 26, 2011 at 19:23
Had the same problem with a out-of-warranty-but-almost-never-used CF50. Needed a replacement circuit board at almost half the price of a new fridge! Service agent cannibalised a dead unit and fixed
mine for about $300.
443144
