Underbody water tanks
Submitted: Monday, Jan 24, 2011 at 12:01
ThreadID: 83862 Views:9932 Replies:7 FollowUps:9
A college of mine had fitted two 20 litre water tanks fitted underunder neath each door sill plumpbed back to to a 12volt tap onto his spare wheel carrier. He has a 2004 Toyota Lancruiser Turbo Diesel (IFS). This was fitted by TJM back in around 2005. TJm no do these and I cant find anyone who does.
Any ideas?
Reply By: chisel - Monday, Jan 24, 2011 at 12:05
This has been discussed on lcool. There are not many options for IFS 100 series cruisers.
1. Opposite lock do a 40L underbody water tank. Something like $750 plus fitting.
2. You can get a combined long range fuel tank and water tank - but you'll need to relocate the spare, and if you don't need the extra fuel then this is probably overkill.
AnswerID: 442886
Follow Up By: Member - Noel C (NSW) - Monday, Jan 24, 2011 at 12:26
Spoke to OOL they said could not help me? Combined warer fuel is not an option either?
FollowupID: 714927
Follow Up By: chisel - Monday, Jan 24, 2011 at 12:56
The code for the tank for an ifs cruiser is WTS100.
http://www.opplock.com.au/index.php?next_page=product/product_detail.php&product_id=7427&category_id=624
I don't have one. I came very close to buying one a couple of years ago but decided it was too expensive and I could cope without.
FollowupID: 714935
Follow Up By: Member - Noel C (NSW) - Monday, Jan 24, 2011 at 18:07
Ok Thanks I rang them back and yes this can be done $1025 ouch
FollowupID: 714975
Reply By: Member - Serendipity(WA) - Monday, Jan 24, 2011 at 12:12
There is a whole range of water tanks sold by Camec and available at most caravan spare parts outlets. They also supply the 12v pumps of various sizes.
I just went online and looked at their water tank sizes until I found one to suit my ute and fitted it up myself with a water pump and and ordinary garden brass tap.
David
AnswerID: 442887
Reply By: Hairy (WA) - Monday, Jan 24, 2011 at 12:31
Gday,
I made my own and fitted it in side the bull bar....maybe another option?
AnswerID: 442892
Follow Up By: chisel - Monday, Jan 24, 2011 at 13:12
I've thought about using some of the space inside the bullbar. Perhaps not ideal to have the extra weight hanging off the front though.
How did you make yours?
FollowupID: 714938
Follow Up By: Hairy (WA) - Monday, Jan 24, 2011 at 16:15
Mine is only around 20kg ( 20 litres) so not enough to even notice the weight but handy for emergencies.
I just folded it out of 3mm plate to suit the shape of the bull barand welded the seems. It fills from the top behind the bull bar and has a braided line running around the inside of the bull bar with a tap on the end.
Its only mild steel as it was all I had lying around, but when it rusts out Ill use it as a template and make one out of stainless.
FollowupID: 714960
Reply By: Notso - Monday, Jan 24, 2011 at 12:41
Met a Stainless steel artisan once, he had replaced his side steps with stainless steel all welded long flat tanks. He reckoned they held about 20 litres each.
AnswerID: 442893
Follow Up By: Hairy (WA) - Monday, Jan 24, 2011 at 16:22
Artisian hey.....I had to look that one up.........sounds like a boilermaker. LOL
FollowupID: 714961
Follow Up By: Notso - Monday, Jan 24, 2011 at 17:45
Yeah mate, I had to use the word as I'd seen it in a dictionary once and had been waiting for the chance! Actually this bloke was one in every sense of the word. He had made all the extra bits on his toyota and caravan, from stainless, just lovely work.
FollowupID: 714970
Follow Up By: member - mazcan - Tuesday, Jan 25, 2011 at 13:20
hi all
duratray make some water tanks also
www.duratray.com.au
FollowupID: 715043
Reply By: Dave(NSW) - Monday, Jan 24, 2011 at 14:32
If your in Sydney try here http://offroadsystems.rtrk.com.au/?scid=4219&kw=3859324 they will do alsorts of water tanks
Cheers Dave.
GU RULES!!
AnswerID: 442905
Follow Up By: Member - Noel C (NSW) - Monday, Jan 24, 2011 at 16:03
Spoke to them. I already have a blackwidow drawer system fitted they advised cant me?
FollowupID: 714956
Reply By: pepper2 - Monday, Jan 24, 2011 at 17:02
In my patrol there is space between the outer metal skin and the internal plastic panel at left hand side rear quarter to fit a 20litre plastic water tank out of site uses empty space made by floatpac in victoria,had it for approx 8 years excellect,they make a range of sizes for various vehicles,worth a thought.
AnswerID: 442915
Reply By: Member - Tezza Qld - Monday, Jan 24, 2011 at 17:08
Hi Noel
Don't know exactly what room you have but have a look here
www.dolium.com.au
Cheers Teza
AnswerID: 442917
