I'm about to open a thread with a very contentious topic. I think we are on the verge of seeing a dramatic shift in the design of vehicles, particularly four wheel drives.
Some food for thought: Fuel prices are certainly not going down; electric vehicles will make inroads into the market in the next ten or so years; a vehicle's fuel consumption is greatly dictated by it's weight; vehicle CAD has resulted in massive improvements in performance, strength, economy and weight reduction in the conventional and some of the 4wd market.
So, with this in mind, I would like to put it out there....What could we be buying in the next decade for the big trip, a fang along
the beach or a weekend in the bush ??
I'm going to make a start:
1. Weight is the single biggest design issue. If we can reduce a 4wd's weight, we improve on and off road performance, improve fuel economy, tyre wear, safety, environmental impact and maybe even accident safety. The (heavy) Troopy I used to have has been replaced by a modern crotch rocket. The frame design of my bike means I have an extremely rigid, yet lightweight box chassis. Can we apply similar design ideas to 4wd's...IE, alloy chassis, aluminium, graphite and composite bodywork and alloy drivetrain components. Remember, the lighter the vechile, the lighter the drivetrain.
2. For this new lightweight vehicle, we need an engine which is powerful, torquey, reliable and with a low centre of gravity. A boxer engine would be good, although we will definitely be seeing electric motors once battery performance is improved, (Even better weight distribution, as batteries can be slung along the floor pan. In the meantime, a flat 4 or 6 turbo diesel with all the new european common rail technology would do.
3. Off road performance - My troopy could go almost anywhere - leaf springs all round, solid axles and a ladder chassis meant it was bulletproof but jesus it was slow, weighed a ton and was scarily top heavy. How about coil springs with long travel, electronically controlled for maximum traction. Combine this
suspension with clearance sensors around the body of the vehicle, to ensure the body doesn't bottom out.
I realise there may be some issues with using our new lightweight 4wd for towing. maybe caravan / camper design will follow with lighter designs ??
Let the discussion begin, unless the moderators label me a nutbag and kill the thread off instantly..
