12 volt timer
Submitted: Sunday, Jan 16, 2011 at 15:08
Member - Noel C (NSW)
Hi I,m looking for a 12 volt timer device which allows me to plug my Engel into which can then be plugged into an Engel socket.
can anyone help?
Reply By: Rod - Sunday, Jan 16, 2011 at 16:12
The 12Volt
shop in
Perth have one on the front page of their website
http://www.12volt.com.au/
down towards the bottom in purple. You'll have to add the engel plugs/sockets
442035
Follow Up By: Ozhumvee - Sunday, Jan 16, 2011 at 18:07
I've been using one of those for years to run my Autofridge in eutectic mode, 2 hrs in early morning and 2 hrs in the evening. It is never turned off, sits in the shed in the vehicle 24/7 operating on the time clock.
714143
Follow Up By: Cruiser .- Sunday, Jan 16, 2011 at 18:44
I have one as
well. I have fitted it to an electrical
junction box just to keep it all n keep box ice and tidy
They work
well
Cruiser
714146
Follow Up By: kcandco - Sunday, Jan 16, 2011 at 20:27
How much are they?
Kc
714152
Follow Up By: ben_gv3 - Sunday, Jan 16, 2011 at 20:43
They can be found here. $60
Jaycar 12V timer
714155
Follow Up By: Member - Mark E (VIC) - Monday, Jan 17, 2011 at 12:21
Like Peter, I have one of these in my car to run my eutectic fridge and it works a treat. The only downside of the device is that it introduces a number of extra connectors and electronic devices into your fridge circuit which WILL cause voltage drop.
I have tested my setup which uses very heavy cable, properly soldered connectors and is generally wired to reduce voltage drop.
Without the timer in the circuit I get 0.2v drop from the battery to the fridge...quite acceptable under load and with the timer, I get 0.5v drop...less acceptable however.
As said it does work and I use it regularly, but bear in mind the offsets.
Mark
714193
Reply By: Cruiser .- Monday, Jan 17, 2011 at 17:44
Noel C,
I have mounted
mine in an electrical
junction box as shown here
Cruiser
442120
