cheapest online nissan parts source?
Submitted: Tuesday, Jan 11, 2011 at 00:04
ThreadID: 83588 Views:3802 Replies:5 FollowUps:8
ok two part question..
does anyone know an online source (besides ebay) where i can find cheap parts for my patrol td42?
parts i would be interested in would be mainly ones that are very expensive like the injector pump for example.
now for the 2nd part
91 td42 patrol, how much smoke out of the tailpipe is normal?
seems to blow a bit of smoke when shifting past the first gear so 2nd 3rd 4th 5th while accelerating only. no smoke at idle and i'd say normal at start up.
can't really tell the color just looks like smoke.
and i'll throw this last one in..is it normal on this model to hear the tappets ticking while driving ?
Reply By: Mick O - Tuesday, Jan 11, 2011 at 00:38
Try emailing craig at NIZZBITS. Always great prices and highly reccomended on the Patrol4X4 website.
Cheers Mick
AnswerID: 441439
Follow Up By: Member - Alex (SA) - Tuesday, Jan 11, 2011 at 10:45
I have purchased a few genuine Nissan parts from Nizzbits as well. Nothing as major as an injector pump though.
Good prices, good communication and prompt delivery.
Alex
FollowupID: 713541
Reply By: Ruffy-Dan - Tuesday, Jan 11, 2011 at 07:15
A bit of smoke is normal but not usually visible from drivers seat.
If you don't know the colour i can't tell you what it is but from what you described it sounds like fuel smoke. Injectors tested/overhauled is first port of call, unless you know of something else that has been modified.
Dan
AnswerID: 441442
Follow Up By: horsefly4 - Tuesday, Jan 11, 2011 at 08:53
its definitely not visible from the drivers seat only when i'm actually driving behind it.
i had a diesel before, a mitsubishi delica and never notised this happening but that's a totally different car
FollowupID: 713527
Follow Up By: Ruffy-Dan - Tuesday, Jan 11, 2011 at 10:48
Just like most older, more "Agricultural" diesels, you will have some visible exhaust emission. I'd suggest nothing to be concerned about.
Highly recommend patrol a part mentioned below
Dan
FollowupID: 713542
Reply By: Member -Ted - Tuesday, Jan 11, 2011 at 10:21
Try this address, I have found them very good.
http://www.patrolapart.com.au/
phone number 9735 9099
AnswerID: 441462
Follow Up By: Member - Rob S (NSW) - Tuesday, Jan 11, 2011 at 12:39
+1 on Patrolaparts found them very reasonable and helpfull, fast delivery.
Rob
I only ever made one mistake
FollowupID: 713553
Reply By: Member - Duncs - Tuesday, Jan 11, 2011 at 21:35
Can't help with the parts supplier but it sounds like your Nissan needs the tappets serviced. They should be done every 80,000km (I think) and they do wear. If the valves are not operating properly then it would be likely to blow a bit of smoke.
I would recommend taking it to a diesel fuel system specialist and have a full service. It won't be cheap but it will be worth it.
Duncs
AnswerID: 441532
Follow Up By: horsefly4 - Tuesday, Jan 11, 2011 at 22:15
yes i actually heard its somewhere around 40 000 kms, any idea how much it costs to adjust the tappets given the usual $100 per hour labour?
FollowupID: 713619
Follow Up By: Leroy - Wednesday, Jan 12, 2011 at 10:01
No tappets to adjust as they use shims!
Leroy
FollowupID: 713645
Follow Up By: Member - Ed C (QLD) - Wednesday, Jan 12, 2011 at 10:49
TD42 is a push-rod engine, Leroy.. conventional screw & lock-nut adjustment on these..
40,000 km is Nissan's recommended adjustment interval....
Confucius say.....
FollowupID: 713648
Follow Up By: Leroy - Thursday, Jan 13, 2011 at 14:06
Sorry of course. I have 3.0l on the brain at the moment.
Leroy
FollowupID: 713793
Reply By: horsefly4 - Wednesday, Jan 12, 2011 at 16:07
good info, thanks all :)
AnswerID: 441585
