Dual Battery for D-Max
Submitted: Monday, Jan 10, 2011 at 21:38
pedropajero96
Has anyone installed a dual battery system under the bonnet of their D-Max. I have been told there isn't enough room.
I am considering a D-Max Single Cab tray back to take a slide-on camper around OZ, and wanted to have a second battery for the vehicle/winch.
I will of course have one or two deep cycle batteries in the camper for fridges/lights etc but as we know, these are not good for winch/cranking operations
Any help or suggestions would be welcome
Malcolm
Reply By: Member - Tanka (NSW) - Monday, Jan 10, 2011 at 21:45
Pedro,
I have a Colorado dual cab, which is pretty much the same thing. I cannot see anywhere another battery will fit under the bonnet. I am about to get a new tray made, and will be getting the extra battery fitted under there. A single cab ute with a trayback should have oodles of room under there.
Cheers Tanka.
441426
Reply By: pedropajero96 - Tuesday, Jan 11, 2011 at 11:21
Thanks Tanka,
Just what I thought. I have also now seen under the lid and can't think of anywhere to put a second battery ..... so under the tray looks the go.
On the same subject of no under-bonnet space, does anyone know where they put the compressor for front and rear air lockers?
441466
Follow Up By: gbc - Tuesday, Jan 11, 2011 at 16:00
Under the passenger
seat for the compressor.
I was flat out getting my dual battery isolater under the bonnet. Still think it's the best ute I've had though.
Just towed a full size toyota huski 8 bobcat
home on a plant trailer to get it out of the floods - we were evacuated from Pinkenba at 1000 am. Not something I'd normally do but some dingbat (me) damaged the truck last week and it's getting repaired. I'm impressed with how the ute handled it (and stopped it).
713573
Follow Up By: pedropajero96 - Tuesday, Jan 11, 2011 at 16:45
Hi GBC
Isn't it noisey in the cab when you activate the compressor/Locker. I have one in Pajero under the bonnet and it is quite noticeable when I use it.
I was also looking at the idea of using the Air Locker compressor with additional fitting and flow sensor to reinflate tyres, rather than carry an additional compressor for this. I don't think this would work too
well under the passenger
seat.
I presume you have lockers in your D-Max. Was this done by ARB, and is this their solution to locate the compressor?
713577
Follow Up By: gbc - Tuesday, Jan 11, 2011 at 22:14
Mine's a colorado. Yes, it's noisy having a compressor in the cab, but given the amount of time it's activated, and the amount of protection afforded to the machinery, it seems a pretty good compromise.
Nil lockers on
mine but that's how the collie's are done.
I had an incab compressor in the gq that I used to race - you get used to it like anything.
I ran lines to the front and rear with nitto fittings for tyre inflation purposes and used a short length of portable line from there.
713618
Follow Up By: Member - Tanka (NSW) - Wednesday, Jan 12, 2011 at 17:34
You could also mount the compressor under the tray if you were concerned about noise. You would have to try an mount it in something reasonably thief proof though. I had an alloy box bent up for one I had in my old ute, not completely thief proof, but nothing ever is.
If you go and talk to whoever you are thinking about manufacturing your tray, I'm sure that they will have plenty of ideas.
Not sure what area you are in but I have been talking to Obieco at
Tamworth NSW who have been very helpful.
713702
Follow Up By: pedropajero96 - Thursday, Jan 13, 2011 at 14:05
Hey Tanka,
I'm in
Perth and just went to speak with Unicorn (a local tray manufacturer)
I'm going to rough-up a digram af a wishlist tray to cover all these points, including extra space for an extra fuel and
water tank behind the head board ... or replacing the headboard.
My goal is to try and minimise the camper overhang over the rear axle (mid-point of the camper would be ideal), yet still have storage space built in directly behind (or replacing) the headboard.This could then be easilly made theif proof.
713792
Reply By: Wayne&Gaby - Friday, Jan 14, 2011 at 15:49
Can not be done, own a 2010 D-Max LSU and had to put the 2nd battery in
the tub under my brilliant EGR canopy.
Wayne
441818
