Well here is a lesson learned and a tale for all you people who tow ;-)
Got up early and went for a long day fishing, caught lots, got
home, cleaned them all and the boat. Time for a cuppa before putting the boat away
Well its now time to put the boat away, steep driveway leads into the flat under house storage area. As I have done millions of times before :-) unhooked the boat and noticed I for got to put the aerial down (First mistake, do all the unhooking before undertaking another task ;-)
Jump off the boat and get into the car to park it up for the night, to do this I do a 3 point turn in the yard (2nd mistake always choc the boat wheels :-)
Took off and started the 3 point turn (May have helped if I had put the Jockey wheel down and lifted the coupling off the ball)
Well what else can you say...Saw a boat heading past the back of the car that had now popped off the towball - Heart misses 5 beats as steep driveway leads to deep drain then houses on the other side of the road with cars parked out the front - This would be nothing but utter carnage ;-(
There is a happy ending as I did immediately throw the car in reverse and back it into the boat, which in turn ended up jamming on top of the tail
gate. Everything now at weird angles and the boat not quite right on the trailer anymore. Jump out and put multi chocks under the wheels.
Now stand back and think....mmm...very lucky - and look down the
hill to what could have been - I did say very lucky....
Two hours latter after using hand
winches and levers, managed to get the boat off the tailgate, back on the trailer as it should be and back under the house where it was.
Lucky also that its a 5mm plate boat, just a few scratches and a tailgate to panel beat..but hey - what could have been?
Moral to the story - When you are tied make sure your routine to unhook the boat, caravan or trailer includes chocking the wheels even if you park on a flat surface and for gosh sake at least remember to jack the boat of the towball :-)
Some mothers do have them
Cheers Tony
