ABR Sidewinder
Submitted: Sunday, Jan 09, 2011 at 02:05
Navara09
Hey guys just wondering what the ABR Sidewinder isolators and monitors are like. has anyone used them? also what other brands do you suggest i could use and what are they like?
Reply By: Member - Alastair D (NSW) - Sunday, Jan 09, 2011 at 07:46
I have purchased products from ABR and found their service and support very good.
I use Redarc isolators which are Australian made. The support I have received from Redarc has been excellent.
No connection just a satisfied user etc ........
441194
Reply By: Member - bungarra (WA) - Sunday, Jan 09, 2011 at 09:14
Have used their isolators and monitors for my dual battery setup and they are working fine............Derek is helpful and quick to respond to any query
I would use ABR again without hesitation
441205
Follow Up By: Dave B ( BHQ NSW) - Sunday, Jan 09, 2011 at 12:37
I will second that comment.
Dave
713203
Follow Up By: Member - Serendipity(WA) - Sunday, Jan 09, 2011 at 12:58
I will third that. I have ABR isolators and monitors for my dual battery setup and they are great. Great help and feed back from Derek as
713208
Reply By: Member - Porl - Sunday, Jan 09, 2011 at 10:00
I purchased the flyer kit with the isolator built in last year. I subsequently wrote the hilux off against two trees, complete write off, the second battery blew out of the box, and fridge, although secured, blew out the rear canopy window, most of everything small enough ended up outside. The engine was smashed from its mounts and broke the front diff into two.
So what survived? The isolator and charging thing. I salvaged the mass of wires and last week hooked it up to two batteries and a battery charge and lo and behold the second battery was charging.
So, in my opinion, close to indescructible.
441217
Reply By: Member - Graham H (QLD) - Sunday, Jan 09, 2011 at 10:21
Have bought several things off Derek including heavy wiring which was very keenly priced in comparison to the shops.
Also bought a Redarc which after nearly 3 years is still working fine.
He has been helpful when I have been in doubt as to what to use.
441223
