Natmap Raster Mapsheet
Submitted: Saturday, Jan 01, 2011 at 15:30
ThreadID: 83362 Views:2133 Replies:2 FollowUps:1
I have a 2003 Release Of Natmap Raster Mapsheets Can load them on window 7 but cannot open them. Should i throw them out and start again.
Reply By: Member - Niss42 - Saturday, Jan 01, 2011 at 16:05
G'day Peter.
There should be a Raster Viewer program on the disk, this will have to be installed to enable maps to be viewed.
If you have OziExplorer Software installed, you will need the .map files from the OziExplorer website.
Barry
AnswerID: 440358
Follow Up By: bgreeni - Saturday, Jan 01, 2011 at 20:38
You should be able to create the .MAP files using
File > Import Map > All DRG maps on a CD or in a Folder.
FollowupID: 712267
Reply By: The Explorer - Saturday, Jan 01, 2011 at 20:41
Issue you are having relates to the map viewing program and not the maps themselves…so if you want to persist with trying to use the supplied viewing program…..this info may help (though it is in reference to 2005/08 viewing software (they have given up on the 2003 version).
FAQ - NATMAP Raster 2005 and Digital Maps 250K 2008
Other option, as suggested, is use OziExplorer to view the maps - may require a registred ($) version.
Using the Natmap Digital Maps DVD's with OziExplorer
AnswerID: 440374
