Bore Water Stain Remover
Submitted: Tuesday, Dec 14, 2010 at 17:47
ThreadID: 83062 Views:17445 Replies:8 FollowUps:12
Just had a new bore put down, now the side of the wife's white car is light brown...Help, what is the best product for getting the brown stain off, I have used CT18 Truck Wash but that dident work, the Vehicle was a white a Toyota Camry
Reply By: Notso - Tuesday, Dec 14, 2010 at 18:17
Can't remember the name but it is a commercial product that panel beaters use and it is made by Meguirs? Basically used with a buffer.
AnswerID: 438895
Reply By: Member - John Baas (WA) - Tuesday, Dec 14, 2010 at 18:23
CLR should work but I'd use a small test panel first.
Cheers.
AnswerID: 438896
Follow Up By: Member - Christopher P (NSW) - Tuesday, Dec 14, 2010 at 19:08
CLR IS SULPHURIC ACID, ACID AND CARS DON'T MIX!!!!!!
Mate best thing would be to give it a hand polish with a very very fine cutting compound, then give it a glaze coat to remove swirl marks.
wash car in clean water, then give it 3 good coats of a waxed base polish, that way if the bore stains appear your not stuck with a brown car.
wash and wax, wax, wax.
here's a big secret most top panel shops don't tell you!!!!!
Wipe with a clean chamois, not a dirty one, but a clean one. Best way to get them clean, water blast it!!!! just be careful you don't get too excited and destroy a chamois, you can see the dirt come out.
FollowupID: 710696
Follow Up By: Dennis Ellery - Wednesday, Dec 15, 2010 at 20:39
CLR doesn't contain Sulphuric acid.
It contains Phosphoric acid which won't harm the paint if used as per direction.
FollowupID: 710802
Follow Up By: Dennis Ellery - Wednesday, Dec 15, 2010 at 20:44
Ranex and Rust busta are also products based on Phosphoric acid
FollowupID: 710804
Follow Up By: Member - Christopher P (NSW) - Wednesday, Dec 15, 2010 at 21:52
its also used in rust converter as well
and de-oxidene.
okies i stand corrected on CLR.
FollowupID: 710816
Follow Up By: Member - John Baas (WA) - Thursday, Dec 16, 2010 at 00:41
Mind you Christopher, I surmise that H2SO4 would do the job as well. Turn the stain into ferric sulphate I reckon; just keep the conc. low.
Cheers.
FollowupID: 710835
Reply By: Member - Graham H (QLD) - Tuesday, Dec 14, 2010 at 18:39
Give it a clay wash
Buy it at sooper creep
AnswerID: 438899
Follow Up By: Member - Graham H (QLD) - Tuesday, Dec 14, 2010 at 18:40
Dont worry everything will be that colour in 6 months so you wont notice it.
FollowupID: 710691
Reply By: sub - Tuesday, Dec 14, 2010 at 19:27
try nu finish polish.
in an orange bottle.had the same thing happen to me one nite.parked on friends lawn when over for dinner drove home and woke the next morning to find the white patrol was coffee colour down passengers side.got the polish out and took it off easy. hope it works for you.
dean.
AnswerID: 438907
Follow Up By: Member - Peter R (QLD) - Wednesday, Dec 15, 2010 at 19:51
Tooth paste works
Pedro
FollowupID: 710800
Reply By: ExplorOz - David & Michelle - Tuesday, Dec 14, 2010 at 19:53
I learnt a trick recently from a car detailer - but be careful. Mix a solution of truck wash with half water, half acetone put this on in small patches at a time. This is what they use to get rid of all stains and red dust from cars. Do not leave it on it will eat the paint but it will get the job done.
DM
AnswerID: 438908
Follow Up By: Member - mazcan - Tuesday, Dec 14, 2010 at 23:58
hi cobber
i only have ever used a rich mix of truck washleave it on for half an hour then wash off with a soft brush and then cut and polished it no worries
i would not put any acetone in it as that is like paint stripper good luck if you do
truck wash will remove north west dust without acetone if you mix it richly
FollowupID: 710734
Reply By: Allan B, Sunshine Coast, - Wednesday, Dec 15, 2010 at 00:06
Cobber, just convince your wife that "Cappuccino" is the new trendiest car colour. lol
AnswerID: 438927
Follow Up By: GoneTroppo Member (FNQ) - Wednesday, Dec 15, 2010 at 12:26
Allen you are soooo wrong, Cappuccino is soooooo last year.
Hazelnut Latte is NOW. You'll just have to get with it a bit more :-)
FollowupID: 710761
Reply By: landseka - Wednesday, Dec 15, 2010 at 11:54
Cobber, I park my caravan by my lawn and it always gets spray from the bore if an easterly is blowing (always is in summer here).
I use a product from any hardware store called Ranex. It is a rust converter which works a treat on bore stains. Rub it on with a rag, let it sit for a couple minutes (without letting it dry) and rinse off. Stain gone.
Cheers Neil
AnswerID: 438945
Follow Up By: RedJK - Wednesday, Dec 15, 2010 at 12:17
Sounds like the business.
http://www.bondall.com/CustomContentRetrieve.aspx?ID=9436
FollowupID: 710759
Follow Up By: RedJK - Wednesday, Dec 15, 2010 at 12:20
Just noticed the footnote :(
* NOTE : Avoid contact with vehicle paintwork, Colorbond ®, dry concrete, anti-fouling paint, marble & anodised or
galvanised surfaces.
FollowupID: 710760
Follow Up By: landseka - Wednesday, Dec 15, 2010 at 12:38
Fair enough, as I said I have used it frequently on my van with no ill effects. I do as the instructions say though and don't let it dry before rinsing.
I guess they have to use the usual disclaimer for the one in a million problem that may occur.
FollowupID: 710762
Reply By: 3GoBush - Wednesday, Dec 15, 2010 at 16:58
This stuff will do the job.
maguires paint cleaner
AnswerID: 438969
