GU 2 Patrol central locking
Submitted: Monday, Dec 13, 2010 at 20:48
reddeer
Hello.
I have a 2000 model GU 2 patrol st wagon.
Up until now the central locking has been working fine but the last 3 days i havnt used it but when i went to unlock it today to get something out of it it worked and unlocked fine but when i went to relock it with the remote it doesnt lock.
So i
check it a few time,s and it does lock when i press the unlock button but it does not lock with the remote at all.
Does anyone have any answer please.
Also when i try to reset the 2 remotes i have when i pull the key in and out 6 times quickly with the doors lock the
hazard lights on the dash dont flash like they say they should.
Can someone shed some light on this please.
Reply By: Dave(NSW) - Monday, Dec 13, 2010 at 21:17
It's a common problem with GUs
check here www.patrol4x4.com.
Mine has to be locked with the key but can be unlocked with the romote.
Cheers Dave..
438814
Follow Up By: Member - Bucky - Tuesday, Dec 14, 2010 at 06:39
Dave
My remote sits on a ledge in the shed.
I can't be bothered fiddling with it any more.
One day I will lash out, but @ $150 it can wait.
Cheres
Bucky
710630
Reply By: CraigB - Tuesday, Dec 14, 2010 at 09:37
At 11 years old I guess you have changed the battery in the remote control?
438858
Reply By: Member - mazcan - Tuesday, Dec 14, 2010 at 13:58
hi reddeer
have you tryed changing the batterys and when doing al as your remote is an aged one
clean the internal contacts with metho and cotton bud stick or polish them if tarnished or corroded
test the batterys you put in make sure they in good conditon make sure they are above required voltageusually 3v
dont presume that because you just bought them that they are the full quid
i have been caught out with on the shelf flat ones only just 3v or under
i have found with my vehicle it takes more
battery power to lock it
than it does to unlock it
438878
