Vortex or Ultimate or bog standard diesel??
Submitted: Sunday, Dec 12, 2010 at 10:43
ThreadID: 83015 Views:13013 Replies:6 FollowUps:8
Did a search and didn't find anything on this topic......not saying it hasn't been discussed previously just that I didn't find anything :-)
I've read elsewhere and heard various discussions where folks say they get better mileage out of Caltex Vortex or BP Ultimate diesel over the other so called standard diesel fuels (ie Mobil, Shell and the independents). I usually use Shell diesel but just for the hell of it I decided to run a tank of Caltex Vortex and then a tank of BP Ultimate.......guess what.. no change at all to my rather ordinary mileage (2008 D40 Auto Navara with a 160 ltr Opposite Lock long range tank) - still returned an average of around the 14 ltr/100km....(town, highway and with about 400km of towing my 1 tonne Kanga campertrailer).
Now I know that 1 tank it not much of a test but it nonetheless got me to wondering if anyone else out there is using Vortex and/or Ultimate and getting better mileage returns....and are these returns worth the additional cost?
At the moment I thinking I just might stay with the usual Shell fill up.
Reply By: Rockape - Sunday, Dec 12, 2010 at 14:00
Have used Vortex only because that's the only diesel the servo had.
The Vortex made no difference to my fuel consumption at all, the only difference was to my wallet.
The best thing I ever did is add 2 stroke oil into the diesel, motor runs smoother and idles better, it sometimes would just stop when idling down and putting the clutch in, that problem has just disappeared. I have a old mechanical rotary pump so the 2 stroke may not be any good in a common rail motor.
Have a good one
AnswerID: 438672
Reply By: Member - mazcan - Sunday, Dec 12, 2010 at 15:13
hi patrol22
i tried a couple of tanks of b p ultimate in my v w 1.9ltr golf diesel which gave me 2000km's of driving test and apart from a small bit of zip in acceleration it didn't change consumption figures and cost more so i deemed it not worth the extra
i will add i have run 2 stroke in the v w common rail system with results being a much smoother and quieter diesel but no change in consumption figures of 5.2 l/100km - hwy
use of 2st has been discussed at length on here and other sites but i just cant find threads right now for reference
imho the extra paid for the vortex/ultimate isn't worth it unless of course the this type of fuel is recommended by vehicle manufacture and would void your warranty if not used
AnswerID: 438680
Reply By: hoffy - Sunday, Dec 12, 2010 at 17:04
I have tried both Caltex and BP diesel in their latest incarnation and found very little difference.
Have been using 2 stroke oil in a common rail Jeep for 12 months now and it does reduce engine noise, reduces exhaust gas temps (About 30 degees in my case)All that is discussed on the link below. I will certainly keep using it.
Here is the link to a major discussion on 2 stroke oil in diesel fuel.
On the last page of this discussion one of the contributers is about to post some photo of common rail pumps internals with and without 2 stroke oil added to the fuel.
http://www.freel2.com/forum/topic878.html
Graeme
AnswerID: 438690
Follow Up By: Member - Hillel K (VIC) - Sunday, Dec 12, 2010 at 17:54
Hi there
What brand/grade two stroke oil are you useing and what ratio?
HK
FollowupID: 710471
Follow Up By: Patrol22 - Sunday, Dec 12, 2010 at 20:01
Thanks for that link Graeme. There is a similar discussion on the Navara forum but without the science.....I will read this discussion more closely when I have some time to spare.
FollowupID: 710483
Follow Up By: hoffy - Sunday, Dec 12, 2010 at 22:22
Hi HK
At the moment I'm using a cheapie from Supacheap "Gulf Westen" I think. The consesus on the Freelander forum seems to be use a non synthetic 2 stroke oil.
The recommended ratio is 200:1. That woks out for my usual fill of around 70 litres to be 350ml of oil
Graeme
FollowupID: 710496
Follow Up By: Member - Vince B (NSW) - Monday, Dec 13, 2010 at 08:18
Hi HK.
I also use Gulf Western, ratio 200:1 in my NP Pajero.
No problems experienced,
Cheers.
Vince
FollowupID: 710526
Reply By: Flynnie - Sunday, Dec 12, 2010 at 23:20
There is no difference in fuel consumption in my vehicle with Vortex diesel. I use it more to do with injector failure paranoia than anything else.
The main downside is not the extra cost. It is the low flow pump used for Vortex. Used to use the high flow truck pumps. Much quicker especially when I take 150 to 155 litres each fill. Also no concern about accidentally filling up with petrol when using high flow pumps.
Flynnie
AnswerID: 438726
Reply By: poppywhite - Monday, Dec 13, 2010 at 11:45
Marketing, advertising and branding are remarkable things. I dont know if there ia actually any diesel manufactured in Au at either of the 2 refinerys.
Diesel is rated by cetain not RON.
There is an Au standard which is quite wide regarding cetain. Diesel cetain is nor advertised at the bowser or published as far as I know. Caltex/woolworths is 2% bio diesel acccording to NRMA. I dont know about everyware it is not labeled that way here but I have seen the bio label at some larger metro outlets.
I cant answer your question and I dont believe that anyone can. Unless they have inside the distributer knowledge.
Anything else is just plain heresay and wishful thinking.
My vehicle seems a littleless rattly on idle with a splash of 2 stroke but I dont think the range on a tank is greater.
Only an industrial chemest and oil industry insider can answer your question. Everyone else has 3 hands on their bleep .
AnswerID: 438753
Follow Up By: Member - Captain (WA) - Monday, Dec 13, 2010 at 13:12
BP Ultimate diesel is manufactured at the BP refinery in Perth, alongside regular diesel - not sure about other locations but I think the BP Qld refinery does too. The main claim to fame of Ultimate is its <10ppm of Sulphur content, along with better cleaning properties which supposedly keep the injectors cleaner. It also doesn't foam as much and smells a lot less too (perhaps thats the easiset wat to tell if you have Ultimate diesel when refueling). BP - how Ultimate Diesel works
Is Ultimate better than normal diesel? Well, I have always used Ultimate in my vehicle, up until ~Dec 2009 when BP stopped supplying Ultimate. It was still unavailiable in Perth up to July 2010, not sure after that (I was transferred to USA for work for 6 months).
I am not an Industrial Chemist, just a Chemical Engineer ;) I have no affiliation with BP, but have toured their refinery a few times and have seen first hand their Ultimate facility and control room. There is no doubt that Ultimate is a different product to their regular diesel. While Ultimate may be relatively new to Australia, it has been available in Europe and the UK since 2003.
Captain
FollowupID: 710545
Follow Up By: poppywhite - Tuesday, Dec 14, 2010 at 13:47
Thanks I learnt something today. I didnt know BP still run a refiner in the west. Here on the british side of the colony we only here of colourful local identies makeing good for a wile.
Earlier post referes to anti foaming and low volume pump so does a low volume pump = less foaming.
I really do welcome any comments that refer to diesel and experience.
I am willing to change my view on marketing if the evidence is there.
I dont have link and am not willing to search at moment to Au standard for diesel but have read it and is fairly wide from memory regarding cetain level.
One of my points in this post is that petrol RON is posted at bowser and diesel is not.
Driver style is a big factor in range from diesel propelled vehicles probally more than petrol. Easy on the foot goes a long way.
Can we get back to the origional post on diesel.
FollowupID: 710673
Follow Up By: Member - Captain (WA) - Tuesday, Dec 14, 2010 at 15:10
Not sure what you mean by "can we get back to the original post on diesel" - all I have talked about relates specifically to diesel fuel and the original post???.
Here is a quote from Wikipedia which probably best sums up premium diesel "...anecdotal evidence shows that its performance varies depending on how an engine is set up. In most cases, it will make a rough-sounding engine run noticeably smoother, and can also alter the performance characteristics; typically some low-end torque is lost, but performance in the middle of the rev range and above is increased. In some engines however, particularly well-tuned common rail turbodiesels, very little effect can be seen or felt..."
However, long term use of premium diesel can maintain engine performance due to the addition of detergents to clean the fuel injectors and minimize carbon deposits, water dispersants, lubricity additives etc...
In my vehicle, I cannot say that premium diesel actually improves its performance. However, I am convinced it will aid long term performance by minimising the negative effects of diesel combustion and is why I pay the price premium to use premium diesel.
Anyway, Cetane Number is whats used to rate diesel fuel performance - and it is different than the Cetane Index value (which is basically a measure of the base value, prior to additives). Cetane number is a measure of diesel fuel ignition delay and has nothing to do with the calorific value of the fuel. It is possible for a diesel blend to have a higher cetane rating but a lower calorific value than "standard" diesel.
However, a high cetane rating usually leads to increased efficiency of the diesel combustion cycle hence it usually delivers better performance. This is the main reason why higher cetane diesel can, but not necessarliy, improve vehicle performance.
Captain
FollowupID: 710677
Reply By: Member - Lyndon.TAS. - Monday, Dec 13, 2010 at 18:12
Hi all.
Not sure about the diesel side of things, as far as mileage/power etc., however, I can absolutely assure you of an outcome on the petrol side of things. Have owned VW Beetles since 1983, (also build my own engines) and if any car engine can notice the difference in different types of petrol, it is certainly an underpowered Volkswagen Beetle engine. I have used all fuel types and there are 2 clear winners in the fuel stakes here. I have heard that all the fuel is refined by Caltex and distributed around the country under Caltex and the other company logos, but , I don't think this is correct. If it is correct, then it comes down to the additives each company puts into the refined product. Let me first start with Caltex unleaded and Premium, - the beetles, and Kombis, that use this tend to be louder, and when accelerating are noisier, giving the impression of more power, however are actually slower and climbing up hills tend to lose power much more rapidly.(why this is so I can not tell you - perhaps the additives used). The engines tend to run hotter, and if the exhaust is checked after running a tankful, it is black and has a good coating of carbon. When driving later model vehicles the same happens, although it is much less noticeable, and unless you are attuned to your vehicle and its sound and the power, then you possibly would not even notice. As far as the mileage is concerned per tank of fuel, I get much less distance per tank out of Caltex than either of the two other competitors. Many VW Owners in clubs who use their VW's as daily drivers, have tended to agree with this in discussions carried out at times. Best power rating would go BP closely followed by Shell. By this I mean least loss of power travelling uphills. Kilometres travelled per tank of fuel, this best economy would have to go to BP, again with Shell not far behind. The difference on a long flat run with no head or tail winds between a 55lt tank of BP and the same tank filled with Caltex at times vary as much as 60-70klms extra distance travelled with the BP Fuel. Shell affords approx. an extra 50klms more distance than the tank of Caltex. To carry this trial out yourself you will need to limit your speed and accelerate gently and smoothly. I would be interested in what others have to say when they carry out this trial. My trial was carried out with a variety of aircooled volkswagens all with different sized engines as well as a 1999 Nissan Patrol GU ST4500, all with similar results. Fuel was purchased over a period of time from WA, SA, VIC, TAS, NSW & QLD so this could not be bad batches of fuel in any one area/state.
AnswerID: 438783
Follow Up By: poppywhite - Tuesday, Dec 14, 2010 at 13:32
as I pointed out before
petrol = RON
Diesel = cetain
Everything in this post is about Diesel (cetain rating for energy displaced)
If you want to discuss RON and petrol refer to NRMA july/august2010 and make a post about different brands of petrol and your experience.
Sorry but your long and interesting post on your experience is not progressing this post.
FollowupID: 710670
