Microwave safe dinner set for caravan
Submitted: Sunday, Nov 14, 2010 at 13:25
Member - Julio C (VIC)
Hi, my wife is looking for microwave safe (unbreakable ) dinner set for the caravan, but it seems most of them out there are not suitable. could anybody recommend a brand or material that would suit.. Thanks
Reply By: Shaker - Sunday, Nov 14, 2010 at 13:52
Have a look at Corelle dinnerware.
435942
Follow Up By: Motherhen - Sunday, Nov 14, 2010 at 14:00
I have some Corelle bowls and they break as readily as china plates when dropped.
Mh
707141
Follow Up By: Shaker - Sunday, Nov 14, 2010 at 14:06
We hav eused it extensively on cruising yachts & camper trailers & never broken a piece.
707142
Follow Up By: Motherhen - Sunday, Nov 14, 2010 at 14:10
They might be worth a try for Julio then. They are of course microwave safe.
Mh
707144
Follow Up By: Member - John and Val - Sunday, Nov 14, 2010 at 18:16
WE have carried and used Corelle bowls and plates for the past 10 years or so, over a lot of corrugations and have not had a single breakage.
Val
| J and V
- Albert Einstein
707162
Follow Up By: Member - Doug T (NT) - Monday, Nov 15, 2010 at 00:16
I had 3 fall from the top cupboards into the No3 spare tyre I used to have, when travvelling I layed it on the floor, pulled up one day and found I'd left the cupboard door open and 3 Corelle plates landed into the steel wheel, did not break.
707223
Reply By: Motherhen - Sunday, Nov 14, 2010 at 13:58
Hi Julio
Some plastic kitchenware and tableware is labelled microwave safe, but i consider only at low temperatures but personally i still don't use plastic in the microwave. Daughter has a plastic microwave rice cooker which she uses at high heat, so if you can find the same plastic in plates they should be OK. It has the recycling symbol:
Image Could Not Be Found
The only melamine plate i have in the house says not suitable for microwave. Silicon cookware should be OK in the microwave but it doesn't come in tableware.
Perhaps cook/heat in silicon and transfer to your plates. Silicon cookware is ideal for caravanning; flexible, unbreakable and doesn't rattle. We travel with plastic picnic set plates due to light weight and unbreakable. Cheap enough to replace if they get a bit scratched from steak knives. But we don't have a microwave in the caravan.
435943
Reply By: Allan B, Sunshine Coast, - Sunday, Nov 14, 2010 at 14:50
Julio, Google "unbreakable microwave plates" (Pages from Australia), it brings up a stack.
The first link, using polycarbonate, is
here.
435949
Reply By: landseka - Sunday, Nov 14, 2010 at 17:14
I too can vouch for Corelle stuff. If you threw a plate at a concrete floor it would probably break but in normal usage I have never broken one.
A couple times in Big W I have seen someone looking at them and as they were doubting their robustness....I got a dinner plate and dropped it on the floor from shoulder height..."KERACK"....hell of a noise but it bounced! Made everyone in the store look as it was so loud. lol
A friend bought a set of 4
places a couple weeks ago at BW, $52 from memory.
The cups are a different issue though, they are china and WILL break.
Cheers Neil
435962
Follow Up By: Motherhen - Sunday, Nov 14, 2010 at 19:44
Hi Neil
Maybe our bowls match
the cups O: Our house floor is concrete with tiles and is very unforgiving.
Julio, despite thousands of kilometres on corrugated roads, our china coffee mugs are still with us. Packed
well you shouldn't have breakages. We go plastic plates as much for lightening the load as for durability.
Mh
707180
Follow Up By: Member - baffle (QLD) - Sunday, Nov 14, 2010 at 23:56
I bought a set at BCF that seems to be OK so far with the caravan microwave.
707221
