100 series Landcruiser 98 petrol/manual 100 000 km
Submitted: Monday, Oct 27, 2003 at 20:43
ThreadID: 8130 Views:2335 Replies:3 FollowUps:2
G'Day,
I was out at Rover 4wd park last weekend near Tenterfield (great spot) and driving some of the tracks. While in low range 1st & 2nd gear on steep decline under the engine braking, my mate following pointed out i was blowing quiet a bit of smoke. It has never blown smoke before and hasn't since and dosn't use any oil. The engine was working fairly hard but it was also working hard on inclines etc but no smoke. Any idears on what would cause this or has anyone else had this happen before. Thanks in advance, GREAT SITE KEEP UP THE GOOD WORK.
Paul
Reply By: Member - Eric- Monday, Oct 27, 2003 at 21:02
The only thing I can think of , is that on a steep incline you had some oil trapped near the valve , and it got sucked into the combustion chamber . Please also note , faulty brakle masters can alow brake fluid to get sucked into the inlet manifold and blow smoke . Is the vehicle on gas ? if yes it could have been the oil drip feed . If it drove home withought any smoke , I wouidnt worry to much about it . In another 200,000 you may want to start thinking about burning oil lol Venus Bay
AnswerID: 35307
Reply By: Masos Cruiser- Monday, Oct 27, 2003 at 21:44
Thanks Eric ,
No it's not on gas, and didn't blow smoke on the way home. Hopefully theres nothing to worry about.
AnswerID: 35314
Follow Up By: Member - Eric- Monday, Oct 27, 2003 at 22:17
check your oil level , if it hasnt dropped , dont worry about it . I use around 1 litre between services , quite normal for 200 kVenus Bay
FollowupID: 25521
Reply By: mikm - Monday, Oct 27, 2003 at 22:18
G'Day,
Sorry that I can't help you with the smoke problem but would you give me some info on the Rover 4wd park please.
mikm
AnswerID: 35323
Follow Up By: Masos Cruiser- Tuesday, Oct 28, 2003 at 21:05
G'day,
The web site is www.roverpark.com its well worth a trip.
Paul
FollowupID: 25630
