2005 RA Rodeo 3.5V6 maintenance
Submitted: Tuesday, Aug 10, 2010 at 10:39
100 Series
I have a 2005 RA rodeo 4x4 V6 with the 3.5l motor, I was wondering if there is anything in particular I need to pay attention to in respect to the servicing - i.e timing belts etc and when things like this need to be replaced.
Reply By: Member - Toyocrusa (NSW) - Tuesday, Aug 10, 2010 at 20:07
Hi. Timing belt and spark plugs require replacement at 100000 Klms. Oil and filter every 10000Klms Air and fuel filters up to 40000Klms or as required. Transmission and diff oils change around 30000Klms. regards,Bob
426876
Follow Up By: Madfisher - Tuesday, Aug 10, 2010 at 21:00
See my note below, timing belt is 160000, although I done
mine at 145000.
Cheers Pete
697490
Reply By: Madfisher - Tuesday, Aug 10, 2010 at 20:58
It is the same motor as in the 98 on Jacks. It is a superb donk if serviced every 10000ks or every 6 months. Timing belt is due at 160000ks OR 5 years, so yours is due. My Jack only cost $400, so
shop arround. The oxygen sensor is also due at 160000ks, but thats not a biggie $80 at repco.
If you do not service these motors you will not get much more then 200000ks, but if
well serviced they seem to do in excess of 400000ks. We have two Jacks by the way.
Cheers Pete
426883
