oven and stove top 1988 viscount van
Submitted: Sunday, Aug 08, 2010 at 12:21
aggie
HI all
Trying to remove oven and stove top from caravan is to be replaced with burner and grill allowing extra shelving. problem where does one find securing points on the stove to be removed. Have disconnected gas that is always a good place to start , have removed all visible external screws. the item will not budge. Any suggestion welcome
Reply By: disco driver - Sunday, Aug 08, 2010 at 14:26
Aggie,
Have you tried the following, it worked for me on my Viscount of the same vintage.
Take the burner rings off the stove top, lift the stove top off, (it clips on and may need a bit of oomph to lift it off, or with some stoves you have to lift the top from the front to release the rear before you can lift the top out of the way).
There should be 4 screws into the side panels, 2 @ front and 2 @ back on each side. Take them out and you should be able to pull the stove out toward you. Be careful as they are a bit heavy and hard to manipulate.
Hope thgis helps with your problem.
Disco.
426616
Follow Up By: aggie - Sunday, Aug 08, 2010 at 17:57
followed helpful info thanks disco
697185
