micro SD card and Garmin Nuvi
Submitted: Wednesday, Aug 04, 2010 at 20:42
Member - bungarra (WA)
I have purchased a nuvi 3760 that has a memory slot for a micro SD card.
I have shonky maps and a couple of others on my old nuvi 760 SD card..normal size.
How do I get these onto this damn little card?.........?
Thanks in advance
Reply By: Member - Peter H (WA) - Wednesday, Aug 04, 2010 at 21:06
Hi Bungarra
Ok copy all the data from the big card to a directory on your computer. Then I assume you got the adapter with the micro card that makes it the same size as your old card...you just copy all the data back to your new card. If not then put the new micro card into the nuvi and and connect it to the computer via the cord and then copy the directory that way.
I bought the 3760 the other day. Nice.
426207
Reply By: Vernp - Wednesday, Aug 04, 2010 at 21:06
I have the Nuvi 750 and I use TOPO maps on a SD card. To access TOPO once in the SD card slot I go to MENU/tools / Settings / maps and then select Map info and select the map program I wish to use.
Hope this helps you out.
426208
Follow Up By: Member - bungarra (WA) - Wednesday, Aug 04, 2010 at 21:18
Understand how to access the maps on the device or the card in the device..
it is how to get data from the big SD to a small one..however I now understand that it is the adapter I need as neither the desktop nor my laptop has a tiny spot for the micro SD
696776
Follow Up By: anglepole - Thursday, Aug 05, 2010 at 10:11
If you have a USB "dongle" for Telstra Optus etc. they usually have a micro slot, use that and you don't need a converter.
When plugged in it appears as another drive on your computer.
Hope this helps
696804
Reply By: Cruiser .- Wednesday, Aug 04, 2010 at 21:07
Bungarra
You will need an adapter that can take the micro SD card.
Copy the contents of the SD card to your PC, then SD card adapter
Cruiser
426209
Reply By: Member - bungarra (WA) - Wednesday, Aug 04, 2010 at 21:15
Thanks all for the advice...seems like it is the adapter I need.
next question I have Tracks 4Australia on the 760...note on the garmin...not the card....
can I get this off the 760 and onto a card? so as to use on the 3760?
426210
Follow Up By: Morrisongs - Wednesday, Aug 04, 2010 at 21:29
Hi Bungarra
Apologies in advance if this is a half arsed answer, but do you have Map Source? You can plug in the old Garmin use Transfer->Receive from Device, then plug in your new unit and Send To Device. I'm assuming this would work between devices, I've had to zap and replace maps on my 500 a few times. BTW have you got Basecamp? It's
well worth the $'s.
Gary
696777
Follow Up By: The Explorer - Thursday, Aug 05, 2010 at 00:34
"BTW have you got Basecamp? It's
well worth the $'s. "
You'd hope so - It's free!!
Basecamp
696787
Follow Up By: Morrisongs - Thursday, Aug 05, 2010 at 20:23
Hah, right enough! It's just everything else that's been a frickin extra!
696859
Reply By: TerraFirma - Thursday, Aug 05, 2010 at 15:05
Believe it or not you can also buy Ebay kits that enable you to cut your SD card down to Micro SD card size.
426260
Follow Up By: The Explorer - Thursday, Aug 05, 2010 at 15:41
I dont believe it - got a link?
696819
Follow Up By: TerraFirma - Thursday, Aug 05, 2010 at 15:56
Sorry my mistake the kit is for cutting down Simm cards to Micro Simm.
Youtube Link
696821
