Fuel Tank Repair required in Perth
Submitted: Thursday, Jul 29, 2010 at 16:34
Shawn
G'Day All, this one is for the WA guys.
I have just returned from two months in the
Pilbara and need to get my sub
tank repaired. It is leaking (a very slow drip) diesel from a very small split on a weld seam.
Can anyone recommend a repairer in
Perth, where I could get the sub
tank (70ltr Long
Ranger) repaired by having the seam re welded.
It's either a re weld of the seam or a new sub
tank.
Shawn
Reply By: Joe Grace Doomadgee - Thursday, Jul 29, 2010 at 19:32
keep check on your costs, it will most probally be cheaper to fit a new or s/h
tank in as you have to go through all the process of removing it and re-fitting it and if welding up the old one it has to be washed and no trace of fuel left in it before anyone will touch it with a welder (there are other methods but all cost).... if a small leak and it is diesel i would leave it until you get home and pull it all out yourself and get a "mate" to do it .. dont try to "plug" it with all the off the shelf stuff as it may affect the sucess of the weld when they do it
Good luck anyway
425680
Reply By: ross - Thursday, Jul 29, 2010 at 22:17
Try Frank at Alloy Fabrications & Welding
Services
4/77 Buckingham Dr
Wangara WA 6065
(08) 9409 1108
He does all sorts of jobs depending how busy he is
I would also be in touch with Long
Ranger,their tanks are not supposed to do this.
425698
Reply By: Member - Duncan W (WA) - Thursday, Jul 29, 2010 at 23:59
Ultimate 4wd (ex K&N) in Canning Vale build tanks so suspect they repair as
425707
Reply By: eddyoz - Friday, Jul 30, 2010 at 11:46
Had a repair done on a boat tank many years ago.The tank was de gassed[ Rentokill by
Fremantle Wharf]and a certificate issued giving a safe working period for repair.It was tig welded by a local boatbuilder.
As long as you have a certificate stating it is clear of fuel fumes any welder should be able to repair it.
425732
