Camshaft Sprocket
Submitted: Thursday, Jul 15, 2010 at 14:14
80seriescruiser
Thanks for the replies re: moving the crankshaft, done belt is off. I want to remove the camshaft sprocket, there is a bolt at the middle of it used to rotate the engine, if I turn this the who sprocket will move - so how do you take the camshaft sprocket out?
thanks in advance, sunny and warm where I am at least !
Reply By: fisho64 - Thursday, Jul 15, 2010 at 15:10
If you take the tappet cover off you will likely find there is a hex cast/forged on the camshaft to take a 22 or 24mm spanner. Thats how the lux is setup anyway.
424124
Follow Up By: Member - Phil G (SA) - Sunday, Jul 18, 2010 at 17:44
26mm on the 1Hz
694847
Reply By: Malleerv - Thursday, Jul 15, 2010 at 16:14
Are you replacing the Seal? I ask because you do not need to remove that sprocket to replace the water pump.
424129
Follow Up By: Member - Toyocrusa (NSW) - Thursday, Jul 15, 2010 at 20:43
Have to disagree with you there. You need to remove the cam sprocket, timing belt tensioner etc. to enable removeing the seal plate which partially covers the water pump. Maybe some engines are slightly different in various models but thats how it was on the one I did recently. Regards,Bob.
694561
Follow Up By: Malleerv - Thursday, Jul 15, 2010 at 21:51
Yep your right Toyocrusa. Forgot about the seal plate being in the way.
Cheers Matt
694571
