Black Mould Stain on Jayco Eagle Canvas
Submitted: Saturday, Jul 10, 2010 at 09:29
ThreadID: 79968 Views:24620 Replies:8 FollowUps:3
Hello there... I am desparate to find some help please!!! We have a black mould stain on the roof of the bed end to our Jayco Eagle (on the canvas). We have tried a solution of salt & water which made no difference (as suggested in the Shannon Lush Stainless book). Has anyone had any luck in removing such stains, if so please let me in on the secret :) - Thankyou, Fiona
Reply By: Sir Kev & Darkie - Saturday, Jul 10, 2010 at 09:33
Fiona,
Have a read of this very informative thread.
Cheers Kev
Russell Coight:
AnswerID: 423553
Follow Up By: 4HappyCampers - Saturday, Jul 10, 2010 at 10:18
Hi. Thanks for the info. I have already read through that thread. Am a bit concerned with using bleach, especially as he suggests to hose it off. This is a bit hard when its the inside of my canvas thats stained, if you know what I mean. Is there anyone out there that has treated canvas on a Jayco Camper before?
FollowupID: 694004
Follow Up By: Sir Kev & Darkie - Saturday, Jul 10, 2010 at 10:52
Maybe use a very wet cloth and wipe as much of the bleach as possible off??
Russell Coight:
FollowupID: 694008
Reply By: Member - Michael P (QLD) - Saturday, Jul 10, 2010 at 10:59
Hi Fiona,
Bleach is diluted chlorine, I have used chlorine on canvas many times (successfully). Have used it on,the vinyl sides of my Jayco poptop,suggest you try on an area not readily visible. No need to hose off as long as you rinse off with clean water.
Mike.
AnswerID: 423560
Follow Up By: TerraFirma - Saturday, Jul 10, 2010 at 11:02
I concur with that.
FollowupID: 694011
Reply By:- Saturday, Jul 10, 2010 at 11:46
Hi, I have a Jayco finch outback 2000 and had a bad mould stain on the roof of one bed-end. The only way to get rid of mould is to kill it, washing with soap and water won't help. I sprayed on exit-mould, left it for 5 min. and then sprayed with water and wiped with a rag. It completely dissapeared and didn't harm the canvas. Remember that the canvas has a rubber coating on the outside so there is no problem with waterproofing.
AnswerID: 423563
Reply By: Roughasguts - Saturday, Jul 10, 2010 at 12:24
Have you tried steam from the kettle! that should kill the spores.
AnswerID: 423567
Reply By: Rockape - Saturday, Jul 10, 2010 at 14:12
Another mould kill/remover is vinegar (white) and you can get the dilution rate off google.
Enviro friendly, I use it on my vinyl annexe with success.
AnswerID: 423575
Reply By: wombat1 - Saturday, Jul 10, 2010 at 19:56
We have used stuff called 30 seconds from Bunnings with great success.
I just rinse off with lots of water
Just means you will need t mop up inside
AnswerID: 423597
Reply By: bjgard - Saturday, Jul 10, 2010 at 20:50
I use a product called "Magic Eraser" made by Chux. Available in most supermarkets where you get cleaning cloths. It is like a white sponge with a blue sponge backing . You dampen the while sponge slightly and clean using the white side . Just do small areas around a 6" circle lightly squeeze out the sponge and then use the blue side to remove excess moisture from your work. I then dry with an bath towel
BarryG
AnswerID: 423601
Reply By: 4HappyCampers - Sunday, Jul 11, 2010 at 22:02
Thankyou all for your replies! Fingers crossed we have a successful outcome :)
AnswerID: 423708
