Windsor Rapid Wiring
Submitted: Sunday, Jul 04, 2010 at 21:20
ThreadID: 79859 Views:5173 Replies:3 FollowUps:1
Hi.
We have just purchased a 2003 Windsor Rapid Off-Road. The "Marker Lights" on the drivers side are not working. We cannot find the 12V wiring. Thinking it might be behind the panels of the caravan.... Can anyone help ???
Reply By: chips59 - Sunday, Jul 04, 2010 at 22:16
There should be some fuses under the seat on drivers side under mains power box. Have you checked the globe, and if so check earth at the side light location.
Shane.
AnswerID: 423039
Follow Up By: JulesV - Sunday, Jul 04, 2010 at 22:21
Thanks Shane, much appreciated. I will get my hubby on to it.
FollowupID: 693448
Reply By: Member - Graham H (QLD) - Monday, Jul 05, 2010 at 09:00
The usual reason markers dont work is bad earths and a good clean and a new bulb fixes it.
Also give the connectors a rub with fine sandpaper as they corrode and give a bad connection to the bulb.
All the wires run through the walls so you wont be able to get at them without considerable trouble and expense.
Frequently some idiot has put the cover on upside down and it has filled with water. Drain holes are best at the bottom.
AnswerID: 423057
Reply By: Roughasguts - Monday, Jul 05, 2010 at 12:48
You will probably find it's the earth, take the cover off the light and remove and re fit the light mounting screws. On my Rapid those screws got rusty and would not make a good earth. I also made a jumper wire from one of those screws to the earth on the globe. No problems since.
Cheers.
AnswerID: 423073
