2nd Battery in the back
Hi Just wondering the best way to secure down my AGM battery in the back of our kluger to run a engel fridge .. Don't want it in there permanently as it's usually in the camper trailer.
I've got dual battery wiring to an anderson connector which sits in the cargo area Just don't want it all to slide around
Cheers Don
Reply By: Member - Peter R (QLD) - Friday, Jun 25, 2010 at 06:55
This is mine in a 2007 Prado D4D
And the wiring
Pedro
AnswerID: 422058
Reply By: Sand Man (SA) - Friday, Jun 25, 2010 at 07:17
Also have an ABR Flyer, but secured with an accessory bracket and strap.
Image Could Not Be Found
Bill
AnswerID: 422060
Reply By: ss--ss - Friday, Jun 25, 2010 at 07:51
Thanks these look very good, only problem with kluger is there's no floor anchor points only the child restraint point on the back of the seats..
Anyway has given me an idea.. Cheers
AnswerID: 422064
Follow Up By: Sir Kev & Darkie - Friday, Jun 25, 2010 at 08:19
Use a sheet of plyboard cut to shape as a false floor and put some mounts into that. The Ply will be easy to remove when not needed and access holes can be cut to allow access to the rated child restraint points if needed.
HTH
Cheers Kev
Russell Coight:
FollowupID: 692423
