HF Radio Info
Submitted: Friday, Jun 11, 2010 at 19:10
ThreadID: 79253 Views:4092 Replies:5 FollowUps:5
When contemplating the purchase of a HF radio, does one have to buy one of the 2 local brands or are there other brands that one should consider?
One needs to watch the dollar but would like the comfort of remote contact if needed.
Thanks for the help.
David
Reply By: qubert - Friday, Jun 11, 2010 at 19:15
icom make a two way that transmits on uhf vhf and hf
AnswerID: 420471
Follow Up By: SNAKE No1 - Friday, Jun 11, 2010 at 20:27
But not type approved for LM use such as VKS etc and it also is an Amateur Radio requiring the appropriate license.Cheers Snake
FollowupID: 690676
Follow Up By: Member - Kiwi_In_Aussie(Wagga) - Friday, Jun 11, 2010 at 22:49
The Icom IC - F7000 is type approved for VKS and does not require an Amateur license
FollowupID: 690686
Follow Up By: SNAKE No1 - Friday, Jun 11, 2010 at 23:25
Hi Kiwi, the ic 7000 is only HF not VHF<UHF. Cheers Snake.
FollowupID: 690693
Follow Up By: Member - Kiwi_In_Aussie(Wagga) - Saturday, Jun 12, 2010 at 18:25
snake - you are correct - I should have responded as a "reply" to original rather than a 'response' to your answer
FollowupID: 690742
Reply By: blue one - Friday, Jun 11, 2010 at 19:26
Mate,
There a few fundamentals and you really have to research what is available and what suits your requirements.
To answer your question Codan or Barrett.
If you don't have the inclination or time to do the detail then go with a NGT Codan and VKS737. They can cover all of the outback and they have a telephone connects if you need it.
If I can help let me know.
AnswerID: 420473
Reply By: Crackles - Friday, Jun 11, 2010 at 23:18
Qmac is another option being compact, simpler to opperate & cheaper than the other 3.
Cheers Craig......
AnswerID: 420491
Reply By: Ozhumvee - Saturday, Jun 12, 2010 at 08:37
For vehicle use there are really only three brands, Barrett, Codan and QMac.
They are designed for rugged use and can withstand the vibration, sometimes questionable supply voltages, dust and dirt that will kill a amateur type set.
Parts and repair facilities for the above (in the unlikely event you may need them) are available Australia wide as well.
There is also the legality of using amateur radios on the HF band if you don't have the appropriate licence.
AnswerID: 420502
Follow Up By: vk1dx - Saturday, Jun 12, 2010 at 08:58
I have an old Yeasu 7070 and an Icom 731. Both have survived mobile operation since I got my callsign in 1980. Don't sell the amateur radios too short.
Having said that; it is worth investigating any "rugged" operation claim by ANY radio before buying it though.
Just as we do with our cars. Otherwise we would not have to modify/upgrade them would we.
I have three options and blowed if I know which way to go. May just get an aldis lamp.
FollowupID: 690704
Reply By: MEMBER - Darian, SA - Saturday, Jun 12, 2010 at 10:16
Staying with the big two, or maybe QMac (owned by Barrett) would be wise in the longer term it seems. Keep the used market in mind - plenty out there, and keen prices do crop up at times (some sellers need to be "told they are dreaming" though :-o). If a prospective purchase goes back quite a few years, check with a service agent re parts and servicing etc. (though the majority of mainstream radios just go for ages without issue). There is a Trader - radio page here - one on the vks737 site too. The various communication retailer/service outlets carry used units as well, but pricing can be "up there" at times (might be justified, if they have been thoroughly checked and carry a warranty).
AnswerID: 420508
