LANDCRUISER 70 SERIES V8TD LIMITED SLIP DIFF FAULTS
Submitted: Sunday, May 30, 2010 at 20:14
tojofixa
Anyone out there experienced any faults with the rear limited slip diff in the new 70 series Landcruisers.
I have a 2007 70 series ute and I have noticed that the limited slip diff does not function as I believe it should. Pulled up on the side of the road today, two wheels on the gravel & the other two on wet grass, slight uphill grade.
When I tried to start off the L/R wheel which was on the grass broke traction, & I didn't go anywhere, just wheel spin on that wheel. Had to engage front hubs & 4wd to get back onto the road. To me this does not seem right as I have a Nissan Patrol that will go in the same
places in 2wd & stopping & starting is not a problem.
Any thoughts would be appreciated as the ute is still under warranty & if it is a diff problem I would like to get it sorted before the warranty expires.
Reply By: Member - Teege (NSW) - Sunday, May 30, 2010 at 20:21
Why not ask Toyota?
teege
418827
Follow Up By: tojofixa - Sunday, May 30, 2010 at 20:32
I am going to the local dealer tomorrow.
Just wanted to know if this is a common fault with Landcruisers before I talk to them.
688970
Reply By: Dave(NSW) - Sunday, May 30, 2010 at 20:30
Get rid of the toyo and stick to the Patrol LOL.
418828
Follow Up By: tojofixa - Sunday, May 30, 2010 at 20:33
May not be as silly as it sounds.
688972
Reply By: Members Paul and Melissa (VIC) - Sunday, May 30, 2010 at 20:36
i dont know why toyota call them an LSD because they are not. they are absolutely useless and always have been. only way to fix that properly is stick a locker in it.
418829
Follow Up By: tojofixa - Sunday, May 30, 2010 at 20:52
If I cant do any good with Toyota that would be my next option.
688979
Reply By: Member - Ian H (NSW) - Sunday, May 30, 2010 at 20:38
The simple answer is that the Toyota LSD does not last very long, say about 40k k's. Our 80 series rear LSD suffers from the same fate.
I hate to say it but the Patrol's LSD is a beauty and seems to go in excess of 200k k's.
I did see a link to a fix for the Tojo's and it was to sandblast the friction faces.
MM me if you would like a contact for the work.
Ian
418830
Follow Up By: Members Paul and Melissa (VIC) - Sunday, May 30, 2010 at 20:48
the LSD in my 100 series was useless at less than 3k, it may
well have been an open diff as thats wen i installed lockers- brilliant.
688976
Follow Up By: tojofixa - Sunday, May 30, 2010 at 20:49
That sounds about right,
mine has done 38000km and I have had suspicions about the LSD for quite a while.
On the other hand the old Nissan
farm ute has done in excess of 300000km and the LSD seems to still work as good or better than it did when new.
688977
Follow Up By: Madfisher - Sunday, May 30, 2010 at 20:56
A little trick with LSDs is to pull on a little bit of handbrake, works on my Jack but not sure about the useless toyo LSDs
Cheers Pete
688980
Reply By: pop2jocem - Sunday, May 30, 2010 at 21:20
It seems to be a given that Toyota LSD's are next to useless and the Nissan version is a beauty. Has anyone offered an explanation as to why this is? As far as I know they both operate the same way and yet they are like chalk and cheese.
Pop
418836
Reply By: Member - Mark C (NSW) - Sunday, May 30, 2010 at 21:31
yep
mine had only done 10000km an it was useless
418841
Reply By: mechpete - Sunday, May 30, 2010 at 21:48
look on the
bright side .
toyo LSD s have been rubbish for 20yrs .at least there consistent
mechpete
418846
Follow Up By: Members Paul and Melissa (VIC) - Sunday, May 30, 2010 at 21:52
agreed, my 80 was useless also and the hilux only marginally better only because it is lighter
688999
Reply By: The Rambler( W.A.) - Sunday, May 30, 2010 at 21:58
Apparently the clutch packs in the LSD of Toyotas wear out quickly effectively turning the LSD intoan open diff. so the best option is a rear locker.I have managed so far without a locker in my Troopy but I think after my trip in a couple weeks I will be getting one fitted.By the way there is a very good article on LSD'S in the Australian 4WD magazine no.148
418849
Follow Up By: pop2jocem - Sunday, May 30, 2010 at 22:28
AFAIK all LSD's use clutch packs, I wonder what makes the Nissan version last so long. They all are "slipping" and therefore wearing out even when driving around town but the Nissan one handles this better???????????????????
I ditched my Toyota LSD a long time ago and fitted an air locker. Works for me although I know some prefer the auto locker (unlocker??)
689008
Follow Up By: Andrew & Jen - Monday, May 31, 2010 at 19:20
Have just fitted a Detroit Truetrac LSD to the front of my Series 80 - unfortunately they do not make one for the rear which is a pity given the potential market of disappointed LC owners. Therefore had to put a diff lock in the rear (ELocker)
My understanding is that the Truetrac does not use clutch packs.
Andrew
689128
Reply By: westozal - Sunday, May 30, 2010 at 22:36
We have two troopies at work ,neither of the LSD's work anywhere near as
well as my mates 300km Patrol.
Get the locker option I think.
Regards Alan
418853
Reply By: Tonyfish#58 - Monday, May 31, 2010 at 18:44
Well - When you pay that much for a car you would expect that option to work.
If it does not, how about a refund of the cost of supplying that option to start with?
My Rodeo is still good with 75k on the clock, but with the situation you were in (and in my country it is often), I find if you put it in 4 low with the front hubs still disengaged and then give it a go, the lower gear speed enables the LSD to work a lot better without the wheel spin. Let the car walk itself as more gas = more spin.
Cheers Tony
418959
Follow Up By: Flynnie - Monday, May 31, 2010 at 19:28
Tony
When I bought the trayback last year LSD was standard at the back. Factory locking diffs were the optional extra.
I have not got much of an opinion of
mine one way or the other. One day if when I start doing
rock climbing I may get air lockers or something.
Flynnie
689134
Follow Up By: Tonyfish#58 - Tuesday, Jun 01, 2010 at 17:04
Flynnie - :-) Sure you were replying to my thread?
My suggestion was to get full use out of the LSD was to put it in 4 low without locking the front hubs. That way you are driving low gears to the back diff.
By doing this the back LSD works a lot better as you are not applying too much power and overriding the LSD.
I do this for towing the boat up the ramp or on my slippery lawns - no hassle of going into full 4 x 4 but gain the benefit of low gear to the LSD.
I think if all the cruiser owners try this that say their LSD no longer works may get a pleasant surprise. Maybe they just give it too much power and thus the LSD Slips as designed.
Regards Tony
689267
Follow Up By: Flynnie - Tuesday, Jun 01, 2010 at 18:27
Tony
It was a reply to your first couple of lines "
Well - When you pay that much for a car you would expect that option to work. If it does not, how about a refund of the cost of supplying that option to start with?"
LSD is a standard fit or was - not an extra cost option. This is only a small point I admit. I might have been being a little pedantic.
I will give your suggestion of using low range without hubs engaged a try.
Flynnie
689286
Follow Up By: Dave(NSW) - Tuesday, Jun 01, 2010 at 22:29
Flynnie,
Will they're at it the should also refund for the ****dy hand brake that never works properly.
689338
Reply By: Members Paul and Melissa (VIC) - Monday, May 31, 2010 at 20:33
re-reading this made me think about other LSDs i have had, this one in a VK Calais, not the worlds strongest diff but it was still fairly tight after 200k. then i increased is power output 4 fold( injected stroker 5ltr) and found it would intermittantly only leave 1 patch, sometimes 2. someone suggested try a LSD treatment so i bought the Penrite one in a little bottle( maybe 50ml if your lucky!) and i tell you what, the longer and harder i drove it the better it got. always 2 patches left no matter how hard i accellerated,turning corners slowly the inside wheel chattered as if it had a locker in it( which i did fit later on) but that stuff did work. never thought to try that on the 80
418990
Reply By: tojofixa - Tuesday, Jun 01, 2010 at 21:42
Many thanks for all your comments & suggestions.
I spoke to the local dealer yesterday & they agreed that there is a problem with the LSD in my ute.
It is now booked in for the repairs to be done under warranty next week.
419173
