are towing mirrors manditory if reversing camera is fitted to van?
Submitted: Saturday, May 29, 2010 at 20:14
ThreadID: 78882 Views:7909 Replies:12 FollowUps:9
I guess the topic just about says it all. Are towing mirrors manditory if reversing camera is fitted to van?
regards Kc
Reply By: CJ - Saturday, May 29, 2010 at 20:30
I didn't know towing mirrors were mandatory in the first place
Are you sure? I am learning every day
CJ
AnswerID: 418696
Follow Up By: Gazal Champion - Sunday, May 30, 2010 at 17:37
Hi CJ,
As far as I know mirrors are mandatory if you cannot see out the back of your vehicle, as would be the case if you have a whopping great caravan 6 feet off your rear bumper. In that case side mirrors are mandatory to see the following traffic so that you may be able to assist them in passing your slow moving vehicle.
I have no idea re reverse cameras negating the need for side mirrors but I would think that it would be advisable to have the side mirrors regardless just in case there was an electrical fault or some other failure.
CJ I realise you did not ask that particular question but I thought it would save a second post.
Cheers, Bruce,
FollowupID: 688927
Reply By: Member Boroma 604 - Saturday, May 29, 2010 at 20:31
Gooday, as far as I am aware it is Mandatory to be able to see clearly down the sides of the unit being towed.
Boroma604.
AnswerID: 418698
Reply By: Member - Royce- Saturday, May 29, 2010 at 20:56
I doubt very much whether reversing cameras are accepted as rear vision.
I'm interested to hear from those who know. I think that they are handy aides but don't replace reversing mirrors at all.
Meanwhile. 'towing mirrors' are designed to extend the rear vision past a trailer that is too wide to see past with your normal exterior mirrors. So they would be mandatory if you are towing something like that.
Maybe you have a camera attached to the rear of the trailer? I'm pretty sure that that wouldn't qualify as an accepted rear view 'mirror'.... could be wrong.. often am!
AnswerID: 418701
Follow Up By: Neil & Pauline - Monday, May 31, 2010 at 11:01
Standard tow vehicle mirrors with a rear view camera meet all the requirements of legislation. See passing and following vehicles. There is no mention of mirrors in the legislation only vision
FollowupID: 689062
Reply By: Tenpounder (SA) - Saturday, May 29, 2010 at 21:05
Hi there.
Strictly speaking, reversing cameras are wired to come on when reverse gear is engaged, and to turn off as soon as neutral or a forward gear are selected. On the contrary, a rear vision camera is wired to be 'on' whenever it is energised, usually by switching it on.
So a rear view camera is supposed to do the same sort of job as rear vision mirrors, but is not legally an alternative. You can be nicked for not having mirrors that meet the legal requirement.
But a reversing camera does not even work when you are travelling forward, so obviously cannot replace mirrors, even ignoring the legal requirements.
AnswerID: 418703
Follow Up By: Member - Duane A (WA) - Sunday, May 30, 2010 at 09:49
G-day iwas told that if you have a reversing camera that can be selected to stay on whilst driving then mirrors were noy needed that is what i have and they work fantastic .I guess it depends on the camera set up you have in place .when iam towing through a city i have the camera on all the time and when iam out bush ill turn it on everynow and then to see if anyone is comming up behind me its a great way to go.
FollowupID: 688875
Reply By: Motherhen - Saturday, May 29, 2010 at 22:06
Yes, you do Kc, certainly in WA, and i think likewise in all the other states. Rear view cameras as a substitute haven't come into the legislation at this stage.
Extract
"Ensure your car is fitted with good exterior mirrors so you can clearly see behind you when towing a trailer or caravan."
AnswerID: 418712
Reply By: WYSIWYG (Bundaberg Qld) - Saturday, May 29, 2010 at 22:06
Found this in the Qld legislation
Site Link
24 Rear vision mirrors
(1) A rear vision mirror or mirrors must be fitted to a motor
vehicle as required by this section so that a driver of the
vehicle can clearly see by reflection the road behind the
vehicle and any following or overtaking vehicle.
(2) At least 1 rear vision mirror must be fitted to—
(a) a car; and
Schedule 1
Transport Operations (Road Use Management—Vehicle Standards and Safety) Regulation
1999
Reprint 5C effective 1 December 2009 Page 59
(b) a motortrike with 2 front wheels; and
(c) a motorbike, or motortrike with 1 front wheel, built
before July 1975.
(3) At least 1 rear vision mirror must be fitted to each side of—
(a) a motor vehicle with a GVM over 3.5t; and
(b) a motorbike, or motortrike with 1 front wheel, built after
June 1975.
(4) A motor vehicle with a GVM not over 3.5t, other than a motor
vehicle mentioned in subsection (2) or (3), must be fitted
with—
(a) at least 1 rear vision mirror on the right side of the
vehicle; and
(b) at least 1 rear vision mirror on the left side of the vehicle
or inside the vehicle.
(5) A rear vision mirror fitted to a motor vehicle with a GVM
over 3.5t must not project over 150mm beyond the widest
part, excluding lights, signalling devices and reflectors, of the
vehicle or combination.
(6) However, the rear vision mirror may project not over 230mm
beyond the widest part of the vehicle or combination if it can
fold to project not over 150mm beyond the widest part.
AnswerID: 418713
Follow Up By: Spade Newsom - Sunday, May 30, 2010 at 11:21
In Qld (maybe everywhere) a reversing camera has no legal standing what-so-ever.
In Qld (maybe everywhere) you must have minimum two mirrors that you can actually see the road behind the vehicle with. ie if towing a van the inside central mirror cannot do that so two side mirrors required.
In Qld (maybe everywhere) the central mirror is mandatory whether it forms any function or not. ie even if you have a ute with a canopy fixed and cannot see anything in the central mirror, you still must have it.
This is what a policemen told me.
Wisiwyg, does what you wrote above say this.
IMO side mirrors are the caravaners primary reversing tool. Reversing cameras are very helpful though and less likely to yell abuse at me when I get too close to the back of the shed.
FollowupID: 688884
Reply By: Member - Patrick (QLD) - Sunday, May 30, 2010 at 07:58
I have both and prefer the mirrors to the camera for reversing. The cameras seem to have a lens that makes distances longer thus making it hard to see what's behind you until it is on you. Saying that I am able to keep an eye out for vehicles that are moving faster than me so that I can move over or in the case of trucks, call them on the radio to work out where it would be best for them to overtake.
I would not be without my Aussie Truck mirrors as they give me a clear view down both sides of the caravan.
AnswerID: 418727
Follow Up By: Gazal Champion - Sunday, May 30, 2010 at 17:47
I agree wholeheartedly Patrick. Mirrors and the like are for helping others get passed safely as well as reversing.
Bruce.
FollowupID: 688931
Reply By: Old Johno [NSW] - Sunday, May 30, 2010 at 11:00
I have found that with good rear view mirrors you can keep an eye on what is happening along the side of your Trailer/caravan (i.e. Windows coming open, bearings getting hot/loose etc.). Plus when another vehicle is passing you can keep a better eye on it. The rear view cameras are great for what is behind you but not along the sides
AnswerID: 418750
Reply By: Member - Graham H (QLD) - Sunday, May 30, 2010 at 11:23
The simple answer is mirrors are a requirement Cameras are considered an aid.
Basically if a cop stands behind your van and sticks his fingers out from either edge and you cant see them in your mirrors you are in trouble.
Also a camera cant see a vehicle that comes up behind you and then sits beside the van far enough forward that the camera cant see it and far enough back that your inadequate mirrors cant either.
Admittedly this will only happen with a longer van but it can and does happen.
On my trip from Coffs to Brisbane and back last week I was amazed at the number of vans with no wide mirrors and some without UHF aerials either.
I also looked for cameras and they had none.
Pulled out from behind a couple and it was obvious from the shifting of the rig they had no idea I was even behind them.
Ignorance is bliss till its an angry Roadtrain driver that wants to pass.
In this instance more is better.
You are after all supposed to watch where you are going and its much easier to glance in a mirror than in a small camera screen usually mounted away from your usual line of vision.
AnswerID: 418752
Follow Up By: pop2jocem - Sunday, May 30, 2010 at 12:40
Yep, same in good ol' Wait Awhile, you must be able to see the rearmost corners of a van or trailer in the mirrors while seated in the usual driving position. As far as I know, and as has been said rear view cameras are considered an aid and are not a replacement for mirrors. Well not at present anyway, I don't know of any vehicle that comes out with a camera and no rear view mirrors at the moment.
Pop
FollowupID: 688892
Follow Up By: Member - Graham H (QLD) - Sunday, May 30, 2010 at 12:51
Even F250's are supposed to use them but some of them have extending mirrors so maybe they go wide enough
Motherhen may help here.
Our buses had no rear vision from the inside mirror as had solid rear panels.
We just got used to using the outside ones but must say a camera would have been useful for the R craniums who delighted in tailgating where we couldnt see them. Same with the van.
I usually wag the tail just to see if there is one there and give the hazard lights a flick if there is.
FollowupID: 688897
Reply By: kcandco - Sunday, May 30, 2010 at 12:49
Thanks everyone for your advice
regards Kc
AnswerID: 418766
Reply By: Neil & Pauline - Sunday, May 30, 2010 at 13:04
The issue is really quite simple. The legislation requires the driver to see vehicles overtaking on either side and any vehicle following. How that is achieved is not stated
Neil
AnswerID: 418769
Follow Up By: ChipPunk - Monday, May 31, 2010 at 03:19
And if a reversing camera is placed on the thing being towed, you can't see its nor your vehicles sides.
Similarly, if the reverse camera is placed at the rear of your vehicle, you won't see down its sides, but you will probably have an excellent shot of the front of the towed object - but NOTHING else.
FollowupID: 689029
Reply By: Member - Graham H (QLD) - Tuesday, Jun 01, 2010 at 10:14
You can actually buy cameras that mount on the side of a vehicle now.
How much I would trust them Im not sure. All these screens to watch when you are supposed to be looking where you are going.
Read this it says about mirrors
http://www.transport.qld.gov.au/resources/file/eb849042963ccb6/Safe_towing_information_V2.pdf
Other sections that should be observed is the bit about chain ratings and the Do not Ovetake turning vehicle signs
AnswerID: 419071
Follow Up By: Member - Graham H (QLD) - Tuesday, Jun 01, 2010 at 10:17
And this one
http://www.safetowing.com/?a=16
Especially this section
16. Mirrors Quality mirrors are essential to safe towing. Buy the best you can afford and ensure that they extend far enough to see behind the van. Cheap attachments that provide limited vision behind and those which vibrate extensively are dangerous.
Remember the old truckies adage _ “If you can’t see my mirrors I can’t see you!” It works the same in reverse – if you can’t see what is behind then your mirrors are in-adequate.The most suitable will vary from vehicle to vehicle depending on both length and width of your touring rig. Some styles are unsuitable for all vehicles. Their location is critical and must be secure. Vibrating mirrors are almost as hazardous as no mirrors and can break the driver’s concentration. A small jockey strap connected to an electrical tie on the wiper blade base will prevent mirrors being blown in by passing trucks.
Always check your mirrors are correctly attached and set before you depart. Do not make adjustment on the move. Stop and get them right before you proceed.
Anybody who doesnt have them is more than stupid.
FollowupID: 689215
