Wednesday, Jun 02, 2010 at 19:41
Hello. We have a customline camper trailer and recently fitted a
water pump.
I fitted it in the kitchen box on the tailgate, and replaced the tap with a small fold down tap over the sink. The pump is a Jabsco Parmax 2, and has its own inbuilt pressure switch. This is a good pump because it has a return cycling function that enables it to run a low flow without having to cycle on and off all the time (down to a certain flow anyway). Max flow is 11L/m, which I actually think is a bit too much flow. Crikey - it'll empty the whole
tank on the trailer in only a few minutes if you left it run!
We fill the
tank in the trailer using an irrigation filter from Kmart, and have also used a Johnson inline filter between the pump and camper
tank.
The pump is permanently wired to an AGM battery in the front box, with a switch and fuse inline. I simply connect it to the
water tank the same as I did when I had the
hand pump. It primes itself and works a treat.
Between the pump and the sink I installed a T piece with a hose with a stopper garden hose connection at the end. This enables us to connect a host to a shower off the front of the trailer using the pump in the kitchen.
In addition, we can disconnect the pump from the
tank under the camper, and connect it to a bucket of warm
water (using our Coleman HWOD) to supply warm
water to the shower. It all works
well, and we are quite happy with the set up.
If you have any more questions, send me a pm or ask away through the thread. Unfortunately I can't upload a photo as I'm a visitor
membership and can't upload photo's.
689439
