towing capacity
we have a toyota hilux TD 2002 could someone tell us why we can only tow 1800 kg?
cheers GG
Reply By: Dave(NSW) - Sunday, May 23, 2010 at 15:31
GG,
Possibly it has the lite weight tow bar fitted.
Cheers Dave.
GU RULES!!
AnswerID: 417805
Reply By: Member - Shane D (QLD) - Sunday, May 23, 2010 at 16:03
Depends on the towbar, there are a number of different "sizes" usually governed by price, however, the last say goes to Toyota.
I'm not sure what your vehicle is rated at (maximum) regardless of how good your towbar is, or how good your vehice tows, Toyota's towing limits must be adhered to.
Shane
AnswerID: 417808
Reply By: Wherehegon - Sunday, May 23, 2010 at 16:33
This what Toyota has rated the capacity at. Vehicle weight,engine, brakes, etc all comes into what the vehicle is capable of. To be honest with a 1kz I wouldn't want to put any more weight behind it anyway. The engine is only rated to 315nm (get more with a chip) 1800 behind is a fair amount of weight.I know the likes of the navara's and some of the later utes are rated considerably more but have bigger motors, brakes and possibly stronger transmissions as well ?? regards Steve
AnswerID: 417814
Reply By: Ianw - Sunday, May 23, 2010 at 19:50
Didn't do your reasearch did you. you allowerd your heart to rule your head. I did my research and bought a 2002 TD Navara, rated at 3 tonne towing capacity. I got no problems.
Ian
AnswerID: 417867
Follow Up By: Member - Phil G (SA) - Sunday, May 23, 2010 at 20:48
Your only problem is that if your D22 is loaded to GVM, then you are only permitted 80kgs for the towball download.
Spec sheets
FollowupID: 687929
Follow Up By: Ianw - Sunday, May 23, 2010 at 22:33
Not quite right, Phil. At GVM I am allowed 100 kgs on the towball. I can put 250 Kgs on the tow ball if I am at 280 kgs below GVM in the vehicle. ie still carry 2640 Kgs in the D22. You are quoting specs from a different vehicle !!!
Ian
FollowupID: 687944
Follow Up By: Member - Phil G (SA) - Sunday, May 23, 2010 at 22:42
I haven't got a spec sheet for a 2002 D22 Navara, so I used a spec sheet for the current D22. Point is that Nissan specify a rather high towing capacity, but put riders on it.
FollowupID: 687946
Follow Up By: Ianw - Sunday, May 23, 2010 at 22:45
No different to any other manufacturer. They all derate towball load according to vehicle load !!
Ian
FollowupID: 687947
Follow Up By: Ianw - Sunday, May 23, 2010 at 22:55
In any case the 2002 Hilux is only rated for 2730 Kg GVM. I can carry this load and have 200 Kgs on the tow ball!!
Letrs face it, Nissan rules !!!!
Ian
FollowupID: 687949
Reply By: Member - Phil G (SA) - Sunday, May 23, 2010 at 20:33
On your model Hilux, the chassis can bend if you have too much towball weight.
AnswerID: 417875
Reply By: Member - Tony V (NSW) - Sunday, May 23, 2010 at 22:08
GG
I checked Redbook and Towing Braked (kg) 1800
Unfortunately thats your lot.
AnswerID: 417886
