Nissan Navara D40 lift kit
Submitted: Friday, May 14, 2010 at 20:37
vcbrock
Just looking for some advice for a lift on a 2010 turbo diesel d40 lift kit.
I have seen kits offering springs struts and rear leaf springs ect from various suppliers. i have also seen the cheaper option which look to be strut spacers for the front with the rear leaf springs re set. I know both give an approx 2" lift
Question is has any one used either and which is the better option??
Thanks in advance.
Reply By: Member - don m (QLD) - Friday, May 14, 2010 at 23:44
G,day vcbrock,
I have a tjm lift installed on my d40. Consists of new coils, shocks and leaf springs using the tjm xgs gold shocks as
well as shackles bushes etc.
Gave me 3 inches of lift. Car steers and handles better than new but given time over I would have gone for a less rigid set up considering how often I am off road or under constant load.
I certainly felt much more comfortable going off road from day 1 of the lift and better
suspension all around being fitted - the d40 out of the showroom sits a little low for my liking and when you load the back or tow something significant the rear sags a bit. The original rear leaf springs sit pretty flat without load so when under load you end up hitting the bump stops often.
On another note, if you add a lift because you are going off road also consider underbody protection. There isn't much there to protect critical things without it.
Don
416735
Reply By: Member - don m (QLD) - Friday, May 14, 2010 at 23:47
G,day vcbrock,
Gave me 3 inches of lift. Car steers and handles better than new but given time over I would have gone for a less rigid set up considering how often I am off road or under constant load. Would thoroughly recommend the change in
suspension. Had a mate at work change on his D40 with a set up from springwood company - doesn't go offroad but now runs his car with big rims and tows a pretty heavy boat. He loves the extra lift and better handling stability.
Don
416737
Reply By: montana - Saturday, May 15, 2010 at 15:09
spacers and blocks are illegal in some state,and you would only make poor
suspension higher,not better.there are a lot of choices for them now from around $1200 for dobinson to 3 1/2grand + for drop frame units.and are adjustable shocks worth the $$ when they wear out in the same time at over double the price of others ?
416772
Reply By: Injected - Sunday, May 16, 2010 at 03:46
Second that as what Montana said. There is no point making avge
suspension higher. Save up and go and see a
suspension specialist. Took my D40 to ARB and i am very happy with the performance and ride of the OME equipment. It transforms the vehicle out of the world.
416836
Reply By: vcbrock - Sunday, May 16, 2010 at 16:03
Thanks for the replies.
I figured that the spacers were a poor option but had to ask all the same.
I will look at getting a decent set up from ARB or Iron man 4X4.
I will also be changing the standard tyres and putting all terrains on.
Bill
416905
