Charge controller
We have a Powertech MP 3129 PV Charge Controller running our 12v system from a 120 watt pannel. The readout screen on the controller has lost all the numbers and just has black squares. Can this be fixed or do we need to buy a new controller
Thanks would appreciate any help
Reply By: Mandrake's Solar Power- Saturday, May 01, 2010 at 13:33
If it still works as a PV controller then there is no need to get a new one unless you particularly want to see the input / output numbers ..
Most of the new controllers and MPPT units only have LEDs to indicate connected , charging and battery SOC ..
Steve
AnswerID: 414961
Follow Up By: ronrox - Saturday, May 01, 2010 at 14:15
Thanks for your reply Steve.... as far as i can make out its still working as the small green light is on....... but i do like to see whats happening
ronrox
FollowupID: 685154
Reply By: Battery Value Pty Ltd - Saturday, May 01, 2010 at 14:28
ronox,
'black squares' makes me think your readout is a 'seven segment LED' type.
LEDs don't burn out just like that. So you'll most likely be able to fix it by opening up the unit and look for bad connections. If there are some cable connectors on the circuit board, wiggle them a bit in their sockets.
Sometimes it even helps to tap the case with the screw driver handle while the unit is in operation, but be gentle.
Best regards, Peter
AnswerID: 414966
Follow Up By: Battery Value Pty Ltd - Saturday, May 01, 2010 at 14:31
sorry RONROX, it was a typo I swear!
FollowupID: 685155
Follow Up By: ronrox - Saturday, May 01, 2010 at 15:47
Thanks Peter, loads of helpful info there, husbands onto it now. Whats in a name anyway? Lots of laughs!!!
Regardsronox
FollowupID: 685168
Follow Up By: Lex M (Brisbane) - Sunday, May 02, 2010 at 13:57
The mp3129 has an LCD display.
FollowupID: 685278
