towing mirrors
Submitted: Tuesday, Apr 27, 2010 at 09:47
Member - bill & netti p (VIC)
Hello members
having borrowed a set off extreme mirrors the ones with strap down the door [know model no] good vision no vibration but wondering if any one has had a problem wearing out window seal where bracket sits.
Bilnetti
Reply By: Member - Vince B (NSW) - Tuesday, Apr 27, 2010 at 11:37
HI Bilnetti.
I have been using these mirrors since last July.No problem with window seal.
I
check the strap tension each morning.
Cheers.
Vince
414446
Follow Up By: Member - bill & netti p (VIC) - Friday, Apr 30, 2010 at 06:55
thanks vince
684972
Reply By: Notso - Tuesday, Apr 27, 2010 at 13:32
I've had em on a Patrol and now on the Triton.
The only thing I do is buy some of the clear stick on paint protection strip from Repco. The pad that sits on the side of the door can rub the paintwork especially with a bit of the Red Heart of Aus under it.
414454
Follow Up By: Member - bill & netti p (VIC) - Friday, Apr 30, 2010 at 06:57
good advice thanks
684973
Reply By: Member - Bruce T (SA) - Wednesday, Apr 28, 2010 at 15:15
Hi Bill and Netti,
We've had a set like that for several years now. We use stick on velcro to cover the metal that sits against the window seal and the window - aim to stop scratching. We also have two wool
seat belt protectors on the straps where they sit against the door. The reason for these was that the belt used to get up a drum at times and annoyed us considerably. No problems since doing this.
They are the best mirrors we have had.
Bruce and Di
414597
Follow Up By: Member - bill & netti p (VIC) - Friday, Apr 30, 2010 at 06:58
thank you Bruce
684974
Reply By: Member - Roger B (VIC) - Wednesday, Apr 28, 2010 at 20:10
All of the above, plus try to get the plate that the mirror sits on as close to horizontal as possible. By doing this, the clamp that goes down the window sill sit straight, and flush with the window, and be less inclined to scrape on the window.
Cheers.
Roger B...
414625
Follow Up By: Member - bill & netti p (VIC) - Friday, Apr 30, 2010 at 07:01
YES IT IS THE PROBLEM THE SCRATCHING I WAS WOORED ABOUT WILL LOOK AT THE ROZZI MIRROWS THEN DISIDE
684975
