Electric Relay
Submitted: Monday, Apr 26, 2010 at 20:41
ThreadID: 78023 Views:2955 Replies:3 FollowUps:3
Gidday all,
This refers to a query I had about a movement cut off switch for the fridge. Refer thread # 78001.
Not being electrically minded, can anyone supply a wiring diagram to fit a relay (electrical cable already in place with a fuse) and also where do you pick the power up in the engine bay so that it will turn itself on or off when you have the ignition on or off. Hope this makes sense.
I have a 2003 Toyota T/D Hilux duel cab and I do not have access to an auto elec.
Tomorrow is here!
Reply By: GerryP - Monday, Apr 26, 2010 at 20:58
Hi Greg,
Why not get one of THESE?
I have had one in my last two vans and they work very well. It simply fits into the 12V lines that feed the fridge. If no movement, then it cuts the fridge power - simple.
I've seen them at camping shops and also at sveral camping and caravan shows. Around $50 all up.
Gerry
AnswerID: 414390
Follow Up By: GerryP - Monday, Apr 26, 2010 at 21:02
Just read your previous thread #78001 and see the Fridge Switch was mentioned before. Still worth considering though. A lot easier than relays and wiring.
Gerry
FollowupID: 684611
Reply By: Mikelb - Monday, Apr 26, 2010 at 21:32
pick up the power to the relay from the windscreen wiper motor connections. Use a test light to find which is the active connection when the engine is running. use this connection to activate the relay.
Mike
AnswerID: 414396
Follow Up By: Member - Phil G (SA) - Monday, Apr 26, 2010 at 22:23
Yep, that's what I use too. On the Toyotas there's usually 5 wires going into the wiper motor - the IGN wire is usually blue and is the middle wire in the row of 3.
FollowupID: 684620
Follow Up By: Member - Greg H (NT) - Tuesday, Apr 27, 2010 at 07:55
Thanks fellas.
Will check it out tonight.
Tomorrow is here!
FollowupID: 684642
Reply By: Member - res.q.guy (Vic.) - Tuesday, Apr 27, 2010 at 07:41
Hi Greg
There are some diagrams here that may help.
Neil
AnswerID: 414417
