No trawling... GU I - III Blow up cause....
Submitted: Thursday, Apr 22, 2010 at 10:38
ThreadID: 77917 Views:4369 Replies:3 FollowUps:10
Hi all,
No no no, not trawling... Looking at buying my first 4WD and deciding between Hliux Surf ($10.000, older and said to have multiple issues), Hilux ($20.000 +, high km's, expensive) or Patrol (GU 3.0TD hopefully series III, 18.000, rugged 4WD but....)
Now I know the series I - II tend to blow up, series III and later seem to have failed to solve the issue and with km's increasing seem to go to (forum wisdom).
My main question is: WHEN do they blow up? Some say only when towing long distances but most people sharing their (1st, 2nd, 3rd or more hand) story don't really mention what they were doing. A local 4WD seller said it is mainly when towing long (1000 km) distance. Some say it's just random...
If I spend $18.000 - $ 20.000 on a GU 3.0TD, I can't afford it to go BANG. No money to fix it....
Or is there a way to avoid it (know some have shorter dip stick or larger sump...)
Won;t be towing more than a 6x4 with camping set-up (700 - 900 kg)
So, to all happy and unhappy GU drivers... help me out here!
Reply By: Dave(NSW) - Thursday, Apr 22, 2010 at 12:28
If you go herehttp://www.patrol4x4.com/forum/ you will get the answers you wont, With Ideas on mods to avoid the" Big Bang"
Cheers Dave...
GU RULES!!
AnswerID: 413893
Follow Up By: DaDutchman - Thursday, Apr 22, 2010 at 13:51
Any idea how much the mods would set me back? Still, would it only warn you of this to come or can you prevent a BANG!!? Waverly Nissan told me that from the GU IV they seems to have gotten better.... But they are around the $30.000, in which case I'd rather go for a good Lux!
FollowupID: 684102
Follow Up By: Dave(NSW) - Thursday, Apr 22, 2010 at 14:22
This will give you an idea of what to do.
Quote:
Originally Posted by MATTY83
Ok I have spent hours looking thru this forum. Looking at what mods to do first and basicly most people are saying this, no order,
. Block EGR
. Fit pyro
. Fit boost gauge
. Fit manual boost control
needle value for dawes set up
alot for the threads mention to do these things but i dont understand why and how they work. So if anyone could explain this to me or send us the previous thread its explained on that would be great.
The order is important IMHO. This is what I would recommend:
1. Order a Dawes valve from 3 Bar Racing in the US. Do this first as they take a few weeks to arrive. http://3barracing.com/product_8.htm
2. Get an EGT gauge. This is arguably the most important gauge for your truck. They should be installed in the dump pipe as close to the outlet of the turbochargers exhaust housing as possible and 550C is the accepted max. I have an after-market exhaust which has a bung in it already.
3. Get a boost gauge. You will need this primarly to set up the Dawes valve and needle valve. After it is set up, it is pretty much set and forget . . . just glance at it every now and then.
4. Buy a new MAF from Garry (nizzbits on the forum). They should be about $220. Keep it in your glovebox until you fit your catch-can.
5. Once you have your boost and EGT gauges installed you can get to know your truck. You will see the boost fluctuate everywhere, this is normal at this stage. Keep an eye on EGTs and back off the throttle if they get over 550C.
6. Get yourself a catch-can installed to stop blow-by fouling your MAF. There are heaps of threads on the forum about this so take a look-see. I am using a modified CKD oil-air separator designed for compressors.
7. After you have installed the catch-can, fit your new MAF. Clean the old one with contact cleaner or MAF cleaner and keep it in your glovebox as a spare (assuming it is not stuffed).
8. When your dawes valve arrives, fit it in a boost limiting configuration. This will mean your ECU is still controlling the turbo boost but overboosts will no longer occur. It should limit to around 16PSI max. Your boost gauge will tell the story here. Best to drive around for a week or so like this, just so that you limit the number of changes you do in one hit. Just makes troubleshooting easier if anything doesnt work out.
9. Next step is to get your needle valve. There are a few options, but I use a FluTec DV-6. Was $35 when I bought it a while back, but they have gone up since.
10. Block your EGR and fit the needle valve at the same time as well as bypassing the Nissan factory boost control solenoid. This is where things really start to get interesting as you now have total control over max boost and the spool rate. By this time you should be seeing lower EGTs on average and having a more responsive bus to boot. You need to do the EGR block/needle valve/solenoid bypass at the same time as they all work together.
I have done some other things and while they are really in the search for performance, EGTs have also benefited.
- 3" exhaust
- I/C fan
- recored I/C
- Lift pump
- Shift kit in the auto
- Trans line pressure solenoid resister mod
- T/C lockup, etc, etc, etc
GU RULES!!
FollowupID: 684107
Follow Up By: Outbacktourer - Thursday, Apr 22, 2010 at 16:51
Boy, that is the whole enchelada ain't it.
I started with the gauges, clean my MAF and bought a spare.
Having monitored it for a couple of years now I'm pretty confident I'll see anything strange going on. Boost fluctuates from 5-7 at cruise to 15-18 when the boot is in. I've never seen more than 450C
I did buy a catch can but have not fitted it yet. The filter goes get dirty on the upstream side so there is definitely blow back but it you clean your MAF at each oil change you should be OK.
OBT
FollowupID: 684126
Follow Up By: DaDutchman - Thursday, Apr 22, 2010 at 17:13
DAVE,
That sure is a great explanation. How much did that roughly set you back (incl / excl labour?). Will see if buying a fairly low km GU I - III with these mods would be worth it...
FollowupID: 684127
Follow Up By: Dave(NSW) - Thursday, Apr 22, 2010 at 18:52
Dutchy,
It wasn't my car I have a 4.2 Patrol, It was one of the guys on the Patrol Forum, Like I said if you check on that forum you will get heaps of info on Patrols.
Cheers Dave..
GU RULES!!
FollowupID: 684142
Follow Up By: DaDutchman - Thursday, Apr 22, 2010 at 19:14
Cheers Dave,
Been reading forums for ages now (not just on the patrol) and haven't come across it yet...will keep searching! Cheers!
FollowupID: 684149
Follow Up By: Dave(NSW) - Thursday, Apr 22, 2010 at 19:19
Try herehttp://www.patrol4x4.com/forum/
GU RULES!!
FollowupID: 684151
Follow Up By: puttputt - Thursday, Apr 22, 2010 at 19:41
Why bother with the drama, rather get the patrol 4,2 or petrol on gas, or cruiser or pajero.
Don't tempt fate!!!!
FollowupID: 684154
Follow Up By: Member Brian (Gold Coast) - Friday, Apr 23, 2010 at 07:51
"puttputt posted:
Don't tempt fate!!!!"
I'm with puttputt FWIW.
In fact, the only way I would buy a 3.0 is if I could follow the footsteps of Project TONI and change the engine out immediately for something else. But that means big bucks up front, so I stick with my reliable GQ. They're getting harder to find good ones admittedly, but the GQ and the 80 series Toyota are near-as-dammit unbreakable IMO. Keep them maintained and they won't let you down.
Brian
FollowupID: 684206
Reply By: On Patrol & TONI - Thursday, Apr 22, 2010 at 21:14
They still go bang.
It's still a lottery as to your chances of it happening to you.
Maybe??????? the common rail models are better.
see my blog
My ZD30 blog
AnswerID: 413950
Reply By: Member - Phil G (SA) - Thursday, Apr 22, 2010 at 21:27
I wouldn't buy a vehicle I couldn't trust. Both of the vehicles - Surf and ZD30 Patrol fit into this category. They are cheap for a reason!!
If you've got $20k to spend, then buy a better vehicle - an 80series landcruiser or a GQ patrol or a 2.8L Pajero. Get a vehicle that is known to be reliable and will retain good resale value.
Keep a few $$ up your sleeve - all vehicles of this vintage need a few $$ spent on them.
AnswerID: 413954
Follow Up By: DaDutchman - Thursday, Apr 22, 2010 at 21:35
Agree.... couldn't drive a car that could blow up any moment.... The surf has issues, but I'd have $10.000 up my sleeve....
Starting to take smaller SUV's and AWD's into the equation, 4WD's will push the budget (either purchase or repairs)
FollowupID: 684172
