Hugh River Stock Route
Submitted: Wednesday, Apr 14, 2010 at 14:43
ThreadID: 77714 Views:3751 Replies:6 FollowUps:3
Related Pages
Just planning the leg of our journey from Yulara to Chambers Pillar and am interested specifically on the Hugh River Stock Route.
How many hours should I expect to be on the stock route from leaving the Stuart Highway till reaching the Maryvale road ?
Reply By: Member - Teege (NSW) - Wednesday, Apr 14, 2010 at 15:22
Rod
Generally speaking it is a very good gravel road.You should sit comfortably on about 80kph or even more if that is your go. It's only about 65 k's, so less than an hour. Just watch out for long, fast moving trains!!!
teege
AnswerID: 412901
Reply By: Motherhen - Wednesday, Apr 14, 2010 at 15:30
Hi Rod
Is this imminent as rain is changing conditions at present in the region?
Are you towing?
We returned from Chambers Pillar via the Hugh SR in 2008 in mainly dry conditions. We were towing, and speeds varied but no different to any dirt road. Just watch for a few dips on the Hugh particularly if towing. A couple of them needed caution. I didn't record times, but it probably took us between one and two hours on the Hugh. We met a thunderstorm and just got back to the highway in time.
Getting to Chambers Pillar from Alice Springs, we had lunch at Ewaninga and got to the camp ground well before sunset. By far the worst bit was the last leg from Maryvale to Chambers Pillar.
I hope these times give you some indication.
AnswerID: 412905
Reply By: Rod - Wednesday, Apr 14, 2010 at 15:58
Thanks for the replies. I'll work on 1.5 to 2 hours then which seems conservative. Yes I will be towing an offroad CT
AnswerID: 412907
Reply By: Member - Rob S (NSW) - Wednesday, Apr 14, 2010 at 18:14
Hi rod
It is not sign posted well,only a small sign to Maryvale, easy to miss
I was looking for as sign Hugh river stock route, DOH,
15 klm later better do a u turn.
Watch the trip meter from Stuarts well 10 klm.
Rob
I only ever made one mistake
AnswerID: 412922
Reply By: Member - Stephen L (Clare SA) - Wednesday, Apr 14, 2010 at 19:09
Hi Rod,
Like all the above it is an easy track to tack with good signposting, just follow the signs. If it is wet, then like all outback road I would keep clear of it.
Image Could Not Be Found
Smile like a Crocodile
AnswerID: 412931
Follow Up By: Member - Rob S (NSW) - Wednesday, Apr 14, 2010 at 20:41
I should have said the sign on the Stuart hwy to Maryvale is only small and easy to miss. when i was there.
That sign is at the Old Ghan intersection.
FollowupID: 682975
Follow Up By: Member - Stephen L (Clare SA) - Wednesday, Apr 14, 2010 at 21:30
Hi Rob
We did not find it a problem. Another way to find it is to say that it will be around 29 kilometres north of the Ernest Giles Road turn off, and like you have mentioned, 10 south of Stuarts Well or 101 south of Alice Springs. The most important thing is to keep an eye on your odometer reading and you will not be far out, after all the Hugh River Stock Route is a major, well used road and not a two wheel hard to find track.
FollowupID: 682982
Reply By: Peter_n_Margaret - Wednesday, Apr 14, 2010 at 19:43
Call into the gallery at Tiyjikala. They have some great artests.
OKA196 Motorhome.
AnswerID: 412938
Follow Up By: Peter_n_Margaret - Wednesday, Apr 14, 2010 at 19:44
......artists..........
FollowupID: 682966
