Prado Air Filter
Submitted: Wednesday, Mar 24, 2010 at 20:23
ThreadID: 77155 Views:7012 Replies:4 FollowUps:7
Related Pages
Hi all,
Has anyone out there managed to find a K&N Filter in their 2003 3.0ltr TDsl Toyota Prado?? Their website says that they do not make one for this model. Has anyone managed to get one that fits, or are there any other recommendation's for High Flow Air Filters, as I am not that impressed with the Genuine Toyota one
Cheers in advance
Pickles
Reply By: Rockape - Wednesday, Mar 24, 2010 at 20:29
Pickles,
can I ask why you don't like the tojo paper filter.
Have a good one
AnswerID: 410254
Follow Up By: Pickles72 - Wednesday, Mar 24, 2010 at 20:46
I guess it maybe OK, but really just wanting a better hi flow filter. Do you have any suggestions?? We are heading away for an 8 week trip through the middle and want everything Mickey Duck before we go
FollowupID: 680139
Follow Up By: Shaker - Wednesday, Mar 24, 2010 at 20:57
Be careful, some MAF sensors don't like oil impregnated filters.
FollowupID: 680143
Follow Up By: Rockape - Wednesday, Mar 24, 2010 at 21:13
Pickles,
Others may disagree with me but here goes.
1. Toyota and Nissan vehicles are used in some pretty harsh country, both naturally aspirated and turboed engines without damage to the internals. (paper elements)
2. Earthmoving equipment opperates in shocking dust with paper elements.
Some of these engines get up huge hours before needing a rebuild.
3. These operators will use the cheapest and best filter they can find, their filters cost hundreds of dollars. They still all use paper filters.
Have a good think about it, I don't believe you will find any performance gain.
All filters let dust through, just some more than others.
There is a test on the net that looked at different filters and paper came out on top.
Have just found it and here it is Filter test
Have a good trip
FollowupID: 680144
Follow Up By: Pickles72 - Wednesday, Mar 24, 2010 at 21:27
Cheers for that Rockape,
Interesting reading! As you have said with the earthmoving guys, we have some Patrols working out in mining country here and they all run standard filters. Makes sense to stick with what the manufacturer suggests really
Pickles
FollowupID: 680146
Follow Up By: Member - Ian H (NSW) - Wednesday, Mar 24, 2010 at 22:00
Pickles,
I have an aftermarket turbo on the 1HZ and was warned not to use foam air filters as even a tiny bit of foam will destroy the turbo vanes should a piece come off. Do as the others have said and stick with genuine Tojo paper filters. They are washable and can be reused.
Ian
FollowupID: 680153
Reply By: Madfisher - Wednesday, Mar 24, 2010 at 21:30
The last thing I would be puting on a td heading into a dusty area is a K@N, ok for street use.You will gain 5% in performance and half your engine life. If You must use a after market filter then use a uniflow and buy extra outer collars so you can change them of an evening. I have used Unifilters and never found dust in the inlet tract, but my use was 90% sealed roads.
Cheers Pete
AnswerID: 410260
Follow Up By: Wizard1 - Thursday, Mar 25, 2010 at 09:29
Have the old 90 series Prado. I have a K & N as well as a Unifilter, one for general running around and highway the other for the dirty stuff. I got mine from TaipanXP.
Unfortunatley the airbox shape changed between the 90 and 120 series TD.
I alslo keep the old Tojo one as a back up. It can also been cleaned and re-used. From what I have read the paper filters are fine, but I didn't find this out until after I'd bought the aftermarket ones.
However the K & N is the easiest and quickest to maintain using the kit. I can wash it, re-oil it and have it back in on the same day(depending on the air temp). The Tojo one, being paper, takes days to dry, and you need turps to clean the Unifilter, yuck!!!
FollowupID: 680190
Reply By: Member - Christopher P (NSW) - Thursday, Mar 25, 2010 at 11:36
With the paper one why wash it when you can blow it!!!!
I take a air blower with me and blow the paper out using my tyre compressor, at home or on the trial, buy the correct fittings, as your compressor blows out at 30- 120 psi!!!!
One air blower compared to a repair kit, or turps, weighs less than 500 grams.
easy to do takes 10 mins and you can enjoy your beer while you do it.
word of warning thou point away from body or you'll be covering yourself and your beer in dust.
AnswerID: 410312
Reply By: Member - ross m (WA) - Thursday, Mar 25, 2010 at 12:54
If you take the time to study this,you will see the K&N filter = more power,for the myth that it is
http://duramax-diesel.com/spicer/index.htm
Ok on 2 stroke motrcycles that get new rings every year or 2
AnswerID: 410326
Follow Up By: Member - ross m (WA) - Thursday, Mar 25, 2010 at 12:54
Someone beat me to it
FollowupID: 680213
