100 Series Service
Submitted: Tuesday, Mar 23, 2010 at 16:41
ThreadID: 77120 Views:3577 Replies:8 FollowUps:8
Have just booked in for my first $1000 plus service. Gives you peace of mind doesn't it ?.
Reply By: Dasher Des - Tuesday, Mar 23, 2010 at 17:24
Does it?????
What is the apprentice doing the night before.
AnswerID: 410086
Reply By: Rod W - Tuesday, Mar 23, 2010 at 17:31
The engine oil is the only oil you'll be able to check to see if its been changed. The diffs and gearboxes will be difficult to tell.
AnswerID: 410087
Follow Up By: cruza25 - Tuesday, Mar 23, 2010 at 17:40
when i had my 100 series serviced at my local adelaide dealer i could tell they had changed my gearbox oil because when i drove it home all the new oil was dripping on to the drivewy- the apprentice or highly skilled vehicle technician had forgot to put the filler plug back in,
at the next service at a different dealer they forgot to clip the top back on to the air filter
now i do it all myself as its past warranty and it gets done properley
mike
FollowupID: 680001
Follow Up By: Member No 1- Saturday, Mar 27, 2010 at 11:02
get under the car with some of swmbo's nail polish...dob a button on a plug/nut/washer/gasket etc etc around where the male and female threads or faces meet ...if its not broken after the service they didnt check it?
FollowupID: 680519
Reply By: Falco80 - Tuesday, Mar 23, 2010 at 17:51
It would give the service department more piece of mind l reckon....they know they will be getting paid.
What's included in such a service and what items will you need to check afterwards to make sure they were actually replaced etc..?
AnswerID: 410090
Reply By: Hopper51 - Tuesday, Mar 23, 2010 at 18:11
I won't let the Toyota dealers of Adelaide touch my 100 series TD. I do my own minor services and for major services I go to Alltrac 4wd because they do the job properly and even pick up on important things like cracked fuel hoses that need to be changed and are not preoccupied with putting grease on the battery terminals and painting the tyres black.
They are no cheaper than the dealers - in fact the 80000km service coming up in a couple of weeks will be well over the $1000 because I am getting them to change the auto fluid as well due to all the heavy towing I do.
I remember back quite a few years ago, lying on my back under my 80 series on the banks of the Coopers creek adjusting the belt on the A/C. The vehicle had been into a dealer for it's 20000km service only 10 days before and because the A/C was an after market one it wasn't part of their service schedule and hence didn't get checked. That was a $500 service. Never been back since.
Chris W
AnswerID: 410091
Follow Up By: Tenpounder (SA) - Tuesday, Mar 23, 2010 at 18:28
Chris W: why should they check another suppliers equipment? should they also check your second battery, the Engel and the inverter? not to mention the UHF radio? Be fair, mate!
FollowupID: 680004
Follow Up By: Hopper51 - Tuesday, Mar 23, 2010 at 19:18
I would say I paid for a factory unit to be done in the scheduled fee - why not do the after market one. Checking and adjusting belts is part of a service. No one expects them to look at fridges, inverters and radios. If I pay for it, I expect it done. Work for a Toyota dealer do you mate?
FollowupID: 680012
Reply By: Tenpounder (SA) - Tuesday, Mar 23, 2010 at 18:18
Well here's a vote for the dealers! I don't like parting with the money any more than anyone else. But here I am, 220,00 plus km and 12 years down the track, all servicing done by these so-called rogues, apprentices and crims you guys like to complain about. Never been stranded; no empty diffs or gearboxes; early warning of impending problems. So I'm with the 'peace of mind' vote!!
AnswerID: 410092
Reply By: Member - Axle - Tuesday, Mar 23, 2010 at 19:50
$ !000, ...Service!!, would give me a ulcer"!!
Cheers Axle
AnswerID: 410111
Reply By: Member - Phil G (SA) - Tuesday, Mar 23, 2010 at 20:59
Theres a lot of work in a major service - I know I've just done my 150,000k service over a couple of weekends. My costs are still considerable and these are from memory:
Diesel Engine oil - $60
Genuine Filter $30
Main fuel filter $40
Fuel Pre filter $25
Toyota Coolant $40
Toyota Brake Fluid $10
LS90 Diff Oils: $40
VMX-M Gearbox/Transfer oil: $50
Wheel bearing grease $12
Timing Belt: $55
Valve clearance adjustment.
Handbrake adjustment
So about $360 worth of parts - mostly at discount price.
In addition I gave it a bit of a treat and an upgrade because I'm planning on keeping it another 8 years:
Timing belt tensioner bearing: $100
F&R Bendix Pads: $140
DBA Slotted Rotors x4: $440
New Japanese wheel bearings and seals: $220
Genuine Water Pump $180
Genuine thermostat $30
Genuine Radiator hoses $50
Beaudesert 3" exhaust $1055 delivered (cat converter was blocked)
So add another $2200 to keep it all reliable for the future.
So I did all my own servicing and it cost $2560.......:-)))
AnswerID: 410119
Follow Up By: TerraFirma - Wednesday, Mar 24, 2010 at 12:36
You are spot on Phil , when you look after a rig like you have you will reap the rewards.
P.S. Smick looking rig you have too...!
FollowupID: 680074
Reply By: Barra-2 - Wednesday, Mar 24, 2010 at 00:22
I use Motorcare and have been for 15 years with our 4 current cars, and all the previous ones as well.
19 Elizabeth St, Adelaide SA 5000 ph: (08) 8231 9955
On my Cruisers 80k Service they knew we were about to do a trip to the GIBB and Tanamai and after checking the diff oils and they were still ok, left them until I came back for the next service after the trip.
Old fashioned service with Jim and his crew and they will always price better than Toyota.
Cheers from Barra
AnswerID: 410142
Follow Up By: Peter Horne [Krakka] - Wednesday, Mar 24, 2010 at 06:15
Personally I would prefer to put new oil in the diffs before a big trip rather than afterwards.
FollowupID: 680049
Follow Up By: Barra-2 - Wednesday, Mar 24, 2010 at 07:12
Yes Peter you would be right on a normal trip, but with our trip we knew there would be over 30 water crossings and diffs can sometimes suck in water which can muck up the oils. And as stated, the oils didn't need changing on the 80 K service because they checked them and didn't need changing yet.
But the real good news was, because I installed extended Breathers to the Diff's, Gearbox and the Crank case after that service and before the trip, no water got into any of the oils.
But my point was the mechanics at Motorcare listen to the customer, and look after you and your car, better than just following the service book.
Cheers from Barra
FollowupID: 680050
Follow Up By: Off-track - Saturday, Mar 27, 2010 at 12:06
I too would generally change diff oils 'early' as this is when they make the most metal - as they're bedding in. Personally I would also do it after a big trip with water crossing too. Not expensive, cheap insurance.
FollowupID: 680528
