Sunday, Mar 21, 2010 at 21:07
I replaced
mine a few weeks back too. Its got 149,700 on the speedo - I'm just waiting for
mine to tick over 150, 000 so I can see the light come on :-))
79series have the electronic speedo. Its the same technique as the 100series - I've lifted the following off LCOOL:
1. T-BELT MODE DISPLAY
a) With ignition turned ON, using the trip switch (select/reset button) change the display to ODO, and turn the ignition OFF
b) While pressing the trip switch, turn the ignition switch ON and hold it for 5 seconds.
c) Release the trip switch, then press the switch again within 5 seconds.
d) The digital display should change to T-belt mode. The initial display "15" (0,000km) is displayed (ie. 150,000km).
2. REWRITING REPLACEMENT VALUES
While in the T-Belt mode, each press of the trip switch will change the displayed value by 10,000km increments. Once " 20 " (200,000km) is reached the display reverts back to " 1 " (10,000km) again. Remember, this setting is the number of kilometres to be travelled before the light comes on next, and once reset this counter will start from zero.
I believe the timing belt interval for all the 100 series engine variants is 150,000km, but this should be checked against each different markets servicing recommendation. This being the case, you shouldn't need to change from the default setting of "15".
3. T-BELT WARNING RESET COMPLETION
a) After setting the replacement setting value, hold the trip switch ON for more than 5 seconds then release the switch.
b)
Check that the display has now changed back to ODO and that the warning light has gone off when the engine is started.
NOTE: If the T-Belt mode is completed, even though the belt replacement has not been performed, the T-Belt warning IS reset.
I hope this proves to be of assistance guys, as usual all care no responsibility. ;-)
409833
Follow Up By: Member - brett g (VIC) - Sunday, Mar 21, 2010 at 21:42
Thanks Phil
Done what you said all good thanks mate changed my belt 145000 at
home six months ago now on a trip around
the block for a year or more and the light came had not gave it a second thought . If i run in to you somewhere its my shout.
Cheers Brett
679780
Follow Up By: Member - Phil G (SA) - Sunday, Mar 21, 2010 at 21:52
Happy to help Brett. I've posted this info a few times over the years - usually after others have said to remove the grommet or pull the speedo out and move the screw - because these were the methods used on the mechanical speedos on previous models. Enjoy your trip!
679783
Follow Up By: Phillipn - Tuesday, Mar 23, 2010 at 07:01
Is the same procedure used to reset a Prado?
679940
Follow Up By: Member - Phil G (SA) - Tuesday, Mar 23, 2010 at 18:51
Yep, Prados use the same procedure.
680006
Follow Up By: Phillipn - Tuesday, Mar 23, 2010 at 20:40
Phil G
Thanks for the reply.
680021
