fitting shock absorbers
Submitted: Sunday, Mar 21, 2010 at 14:42
the nugget
Have a collapsed shockie on rear of GU Patrol Wagon. Never fitted shockies before.
Have bought replacement shocks. Do I need to jack up each wheel prior to fitting shocks.
Thanks, Nugget.
Reply By: Member - Mark G Gulmarrad - Sunday, Mar 21, 2010 at 14:50
Nugget
you dont have to remove wheel to fit the rear shocks,just put your jack under your diff,(jack up to a height where you can comfortably slid under your car)then place car stands under your chassis and let jack down slowly to rest on these stands and leave jack under your diff.this way you can adjust height of the car to fit new shocks.
it will be an easier job to do the front with the wheels off and repeat the last procedure only place the jack under the front end cause your diff will be offset,cheers.
409765
Follow Up By: the nugget - Sunday, Mar 21, 2010 at 14:56
Thanks Mark,
I have done a fair bit of work on vehicles etc, but never had to replace shockies before.
I didn't intend to remove the wheels, but I wasn't sure if I had to jack up a bit to fit the shocks.
Front ones are ok.
Thanks again, Nugget
679672
Follow Up By: Batboy - Sunday, Mar 21, 2010 at 14:56
Hes got a Patrol so should be plenty of room underneath, no jacking required
Compress or extend the shocks to match the studs rather than jacking the car
679673
Reply By: Batboy - Sunday, Mar 21, 2010 at 14:52
No mate, Just undo the nuts.
409766
Follow Up By: the nugget - Sunday, Mar 21, 2010 at 14:57
Thanks for your reply Batboy, I will jack up as suggested and use the stands as it will give me some clearance to work under.
Nugget
679675
Follow Up By: Batboy - Sunday, Mar 21, 2010 at 15:06
lol must have a belly like
mine then!
Sometimes a pry bar is handy to get the shock off the lower mount
679678
Reply By: Member - Barnesy - Sunday, Mar 21, 2010 at 15:11
You don't need to remove the wheels or jack up the vehicle. Just undo the nuts and fit the new ones as the old ones came off. Just remember not to tighten the new nuts too much, just enough for the nylon locnut to grab.
Barnesy
409770
Reply By: Off-track - Sunday, Mar 21, 2010 at 15:17
Depends a little on the shocks as
well - some are very hard to compress so you may have to jack the car to have the wheel off the ground and thereby maximise extension.
If they are hard to compress you can use a strap or another jack underneath to help.
409772
Reply By: Cruiser 2091 - Sunday, Mar 21, 2010 at 15:23
As has been said before you can do the job with the car on the ground however sometimes removing the wheel allows better access.
Usually the nuts are difficult to remove from the old shocks, they are usually tightened to about 55 ft lbs.
One thing to be aware of: if you are fitting gas filled shocks hold them in an upright position when squeezing them in to locate them in position. If you don't do this ie if you hold them horizontal then you can induce gas past the valve which can cause a free spot at the top of the stroke. If this happens you will need to press them up and down a few times while holding them upright to bleed them.
Best regards Cruiser
409775
