Iridium phone import
Submitted: Friday, Mar 05, 2010 at 12:23
Member - Mel D (NSW)
Assuming that Iridium phones are the same around the world, I have imported a 9505a from the USA which I bought through ebay. I inserted my pre-paid Telstra SIM card, which is said to have International roaming activated, but the Iridium phone doesnt recognise the SIM card and asks for a card to be inserted. What is wrong?
Reply By: Bob of KAOS - Friday, Mar 05, 2010 at 12:42
Is it a 3G sim card? An old GSM won't do.
Maybe it needs to be a post paid card.
407369
Follow Up By: Member - Mike DID - Friday, Mar 05, 2010 at 17:42
Any working card will be recognised - it just won't be accepted for Registration on the Iridium network.
I have an old SIM card that won't be recognised on teh Telstra network - but it's still accepted as a SIM card in my 9505.
677337
Reply By: Member - Andrew L (WA) - Friday, Mar 05, 2010 at 12:55
As far as I know pre-paid SIM cards will not work.
The SIM must be on a plan and have Global Roaming activated - I use a plan / GR activated Next G SIM in an Iridium 9555 and it also works in my friends 9505a.
Have you tried the SIM in another Iridium phone? Or a plan / GR activated SIM in the phone you have purchased?
Leachy
407374
Reply By: Member - Fred B (NT) - Friday, Mar 05, 2010 at 13:30
Pre-paid will definitely not work... must be on some sort of plan with global roaming activated.
regards
407378
Reply By: Geoff (Newcastle, NSW) - Friday, Mar 05, 2010 at 16:06
There's your problem: "I inserted my pre-paid Telstra SIM card,"
The card can be either GSM or 3G or whichever "G" Telstra flogs.
It must also have International Roaming enabled but definitely cannot be prepaid.
The pin pattern on the cards appears to be quite important to an Iridium too.
See this photo,
The top and middle SIM's in this photo are both Telstra GSM's on a plan. The bottom SIM is a clone of the top SIM.
Top and bottom will both work in my 9505A, the middle will not. It causes a bad SIM error on the 9595A.
All three SIM's will work in the two ordinary Nokia handsets I have here, one GSM, the other 3G.
There are SIM's and there are SIM's but the one you put into an Iridium handset must be Telstra and be on a plan. Definitely not prepaid.
| Geoff,
Landcruiser HDJ78,
407397
Reply By: Member - Mike DID - Friday, Mar 05, 2010 at 17:48
If it asks for a card to be inserted, you have an electrical SIM or SIM socket problem. If someone's been careless inserting SIMs the socket could be broken - they're very fragile and are often sold as spare parts.
Try another SIM - ANY SIM. Unless the card is damaged or the wrong pattern it will be recognised by the phone.
To be registered on the Iridium Network it must be Postpaid etc. but that happens later in the process.
407416
