Thermostat switch
Submitted: Friday, Feb 26, 2010 at 20:35
ThreadID: 76366 Views:3927 Replies:3 FollowUps:6
G'Day
I have spent this arvo installing and wiring a 12v computer fan on to the basket between the Waeco and the Two-Zone.
It works fairly well but is there a thermostat that would sit on the wiring inside the Two-Zone to control when the fan goes on/off..?
I left the fan running for 4 hours and the Two-Zone got down to 1.5C which is a bit too cold...
Thanks if you can help
Jedo
Reply By: Jedo_03 - Friday, Feb 26, 2010 at 22:01
So...
IS there a such a thing as an internal fridge thermostat that will switch the fan off and on at predetermined temps.??
AnswerID: 406222
Follow Up By: dbish - Friday, Feb 26, 2010 at 23:45
Yes there is from Jaycar KC5476 $33.00 Tempmaster fridge/freezer control unit, works well use one for a Waeco CR80 fridge which had a faulty mechanical thermostat. It could be used to switch a fan on/off. Cheers Daryl
FollowupID: 675939
Follow Up By: The Boss - Saturday, Feb 27, 2010 at 05:43
I wanna know the same thing, i want to install one inside fridge to blow cool air around, but would like it to turn on and off at certain temps.
Cant find anything of the sort.
FollowupID: 675956
Follow Up By: Jedo_03 - Saturday, Feb 27, 2010 at 17:21
Thanks dbish...
Seems that it's a kit that I'd have to build meself... EEEKKkk...
Glad you have one (did you build it yourself..??) cos now I can ask you questions:
How hard/easy was it to build..?
Once built - Is it easy enough to set the controls re on/off temps..??
Can it be programmed to "on" at 5deg and "off" at 2deg - or is it more crude than that?
Thanks for the info
Jedo
FollowupID: 676059
Follow Up By: dbish - Sunday, Feb 28, 2010 at 13:28
Jedo_03, Yes it is a kit requring a hand full of components fitted to a printed circuit board requiring soldering, The fulldescription & construction is in a magazine Silicon Chip (may be on line) Feb 2009 issue, it is adjustable temp by a variable resistor (trim pot) The cutin/cutout (diferential temp) as per orig circuit was to narrow 1deg, Changed 10M resistor betwean P1 & P3 on the integrated circuit (IC) to 2.2M this gives 3Deg cutin/out range. Daryl Un fortunately not member of this site so cant post pictures.
FollowupID: 676221
Reply By: Member - joc45 (WA) - Saturday, Feb 27, 2010 at 01:52
The control box of the Danfoss compressor has an output for a DC fan (if not already installed). This switches off when the compressor stops. Of any use?
AnswerID: 406267
Follow Up By: dbish - Saturday, Feb 27, 2010 at 15:38
Please be aware that the danfoss 12v feed is a max of 500Ma continuous, a higher current is allowed for a max of 2seconds during start otherwise you will get fan overload cut out error of 2flashes on the led. If its a Waeco Fridge freezer it already has a fan & internal globe running of it. If you disconected the internal lamp you may ba able to run another fan .These figures are from the Danfoss compressor data sheet. Daryl
FollowupID: 676044
Follow Up By: Jedo_03 - Saturday, Feb 27, 2010 at 17:24
Joc and dbish...
Ummm - well I'm not really game to start dismantling the Waeco..
But thanks anyway
Jedo
FollowupID: 676062
Reply By: greenant - Saturday, Feb 27, 2010 at 20:55
Hi jedo
This might help but it is turn off at 2 degrees very small
http://cgi.ebay.com.au/Universal-Defrost-Termination-Thermostat-RF027A_W0QQitemZ310186610514QQcmdZViewItemQQptZAU_Home_Appliances?hash=item4838900f52
Greenant
AnswerID: 406393
