Prado wont start...KDJ120r
Submitted: Thursday, Feb 25, 2010 at 14:51
Dremus
I was just helping a mate fit a dual battery set up to a D4D prado when we touched the positive battery terminal on the fuel filter - earthed.
The motor will now turn over but not start... Is there a reset or fuse to replace. I have
check all the fuses I can find with out luck.
Does anyone have experience with this sort of thing?
Reply By: Member - Troll 81 (QLD) - Thursday, Feb 25, 2010 at 15:20
Might be a immobiliser/alarm type problem
405955
Reply By: Member - William B (The Shire) - Thursday, Feb 25, 2010 at 15:29
Hi Dremus,
Sounds like an imobiliser problem or most likely a blown fuse, the toyotas are putting fuses in all sort of strange locations (as are all car makers come to that).
Is that the model that has a big plastic container near the battery terminal?
Check for a ECM fuse or a fuse that has a picture of a engine.
Good hunting.
Will
405957
Reply By: Dremus - Thursday, Feb 25, 2010 at 16:37
Thanks for the input guys.. we found it!
Someone (not me) shorted the spanner out on the fuel filter and put a pin hole in it about 10mm from the top of the filter.
for some reason we couldn't see any diesel but after priming the pump a ni9ce stream of diesel shot out. The engine was sucking air..... put your finger over it and she started..
how embarrassing.. could have been worse, could have been petrol!!!!
405966
