where to fit second battery GQ patrol- petrol/lpg
Submitted: Monday, Feb 22, 2010 at 10:17
ThreadID: 76233 Views:2730 Replies:4 FollowUps:5
hi, we are trying to workout where the second battery goes on our GQ which is a 4.2 petrol with LPG, the only place we have thought it could go is where the air filter is, if so what do you do with the air filter? thanks from chris.
Reply By: Nik & Dee - Monday, Feb 22, 2010 at 12:03
Hi Chris,
I have the 4.2 deisel and mine is mounted on the passenger side, just behind the air filter and along side the radiator overflow tank. There is a mounting bracket that goes around the tank. Don't know what the petrol engine looks like compared to mine so hope this helps. I bought mine second hand it already came like that so don't ask me where the mounting frame came from!
If you want I may be able to post a picutre
Nik
AnswerID: 405371
Follow Up By: gonebush SA - Monday, Feb 22, 2010 at 12:15
hi, thanks for that but from what i have heard the deisel has it mounted a different place to the petrol motors, thanks any way chris.
FollowupID: 675068
Follow Up By: Skippy In The GU - Monday, Feb 22, 2010 at 12:22
Hi gonebush, the main air filter is ontop of the carby but some GQ's have the pre cleaner mounted behind the LH front headlight.
I took mine off and placed the second battery there.
FollowupID: 675070
Reply By: Member - Duncs - Monday, Feb 22, 2010 at 15:47
A neighbor of mine had a Petrol GQ. His second battery was mounted on the firewall, left side and up fairly high.
I don't know if he moved anything to put it there but it was nice and neat and still left foom for a compressor.
Duncs
AnswerID: 405414
Follow Up By: Member - warren G (VIC) - Monday, Feb 22, 2010 at 17:43
duncs is spot on but i didnt have mine on gas it was a long time ago but i dont remember moving anything.cheers warren
FollowupID: 675137
Reply By: gonebush SA - Monday, Feb 22, 2010 at 20:41
hi again, our air filter is on top of motor with the air induction going down to behind the pass side headlight and our gas convertor is near the fire wall on the same side, thanks from chris.
AnswerID: 405479
Reply By: nowimnumberone - Wednesday, Feb 24, 2010 at 18:57
with a gq on gas they usually fit the mixer on the left hand side against the fire wall thats where the gq petrol duel battery goes but if you fit a gq diesel one and a bit of fidling with a few bits coil etc it fits quite good it sits in the same place as a standard battery but on the opposite side ive just finished fitting mine (gq on gas)
AnswerID: 405791
Follow Up By: gonebush SA - Thursday, Feb 25, 2010 at 08:50
hi, yes that's about the only place we thought there was a chance of fitting it but what did you do with the air intake pipe? as ours goes from the airfilter to the rear of the passengers side headlight, thanks from chris.
FollowupID: 675559
Follow Up By: nowimnumberone - Thursday, Feb 25, 2010 at 19:35
ummmmm nothing at the moment im going to buy some flex hose from a vacume cleaner shop and re route it
FollowupID: 675689
