Thursday, Feb 18, 2010 at 17:41
I'm good thanks
If an update has been posted on such and such a date, only info that needs changing or correcting to reflect current conditions will have been changed, so the sum total of the trek notes will be as accurate as can be expected.
You have to remember that the trek note writers do not travel these routes every week, so use them as a guide only, if the 'last updated on' time frame is a bit old. Sure as hell beats not having a guide at all.
I have only used one set of trek notes so far, found an error in it, and will fully log the trek and submit it to the website for consideration, in the near future. Thats how these notes are kept as up to date as could reasonably considered possible, we all do what we can to help our fellow travellers, rather than just looking at the notes, disregarding info we don't personally want, then stating that the info is pointless.
The trek notes are provided in good faith for all users, experienced or otherwise, they are a guide to the area and track you would be following, fuel consumption, distance, driving time, things to see, historical sites etc, side trips,
camp sites, contact names and numbers, fuel supply points, consumable and service centres, safety suggestions depending on isolation status, roadhouse contacts, station names and phone numbers, pretty much everything you need,,,the list goes on and on, and a suggested time you should allow to do the trek, not a hard and fast set of rules that you follow to the letter.
Dunno what more you want
Cheers, Dave
674473
