Bullbar indicator lights
Submitted: Monday, Feb 08, 2010 at 16:41
Coot
Do the indicator lights on a bullbar ,by law have to be connected.If I connect
mine up,the trailer indicator lamp in my dash operates in unison with the vehicles blinkers because it sees the bullbar lamp as another lamp in the circuit (ie the trailer light) and its very annoying,especially at night.
Reply By: Member - RobnJane(VIC) - Monday, Feb 08, 2010 at 16:55
Hi Coot,
Yes they must be connected, as a bullbar will normally obstruct visibility of the original indicator from different viewpoints.
Rgds,
Rob.
403277
Follow Up By: Lex M (Brisbane) - Monday, Feb 08, 2010 at 17:07
You could either remove the bulbs from the original front indicators or replace them with LED bulbs which draw less current.
672760
Follow Up By: Ozhumvee - Monday, Feb 08, 2010 at 18:03
Led globes will probably solve the problem as has been said, the blinker unit won't detect the additional load.
672765
Follow Up By: Shaker - Monday, Feb 08, 2010 at 19:23
I just put 5watt globes in
mine & stopped the dash 'trailer light'.
672777
Follow Up By: Rob! - Tuesday, Feb 09, 2010 at 16:13
I think a 5W globe would be next to useless during daylight hours. A good way to cause an accident.
just my 2c
672895
Reply By: Member - Graham H (QLD) - Monday, Feb 08, 2010 at 17:00
The make of your vehicle would be a help.
I just soldered
mine to the normal indicator and side lights in my Cruiser
403280
Follow Up By: Coot - Monday, Feb 08, 2010 at 18:34
Sorry for the lack of info. Its a new Defender 110 wagon
672767
Follow Up By: CJ - Monday, Feb 08, 2010 at 18:46
No wonder you didn't want to disclose the make of your car
Ha haha haha sorry
CJ
672769
Follow Up By: Rockape - Monday, Feb 08, 2010 at 20:57
Forget the coment about landrover, put led bulbs and you will have no more problems.
672787
Reply By: Gazal Champion - Monday, Feb 08, 2010 at 17:31
Hi Coot, Mechanic once told me at inspection time "if they are fitted they have to work." But from my experience it depends on the person doing the inspection.
If it is an 80 series the bar probably would obscure the originals and it is good policy anyway I suppose.
Hope that is of some help.
Regards, Bruce.
403286
Follow Up By: Member - Timbo - Tuesday, Feb 09, 2010 at 12:46
Bruce, I've been told the same thing - "if fitted, they must work", even though the car may be fully compliant without the additional lamps.
672875
Reply By: Member - Shane D (QLD) - Monday, Feb 08, 2010 at 18:21
YEP,
If there is a light mounted, it has to work, regardless if its "needed" or not, such as side clearance lights on utes, and driving (spot) lights.
I bought a Cruiser from Queensland and registered in my then homestate (ACT) which required me to put it over the Transport department's inspection station, It got failed because the bullbar obstructed the blinkers when looked at from a certian angle and for me to get rego, I had to mount blinkers on the bull bar, that can be seen from any angle, I was preatty annoyed at the time but did it anyway, not that I had a real choice.
Makes perfect sense, no point having a blinker if poeple can't see it!
Shane
403295
Reply By: Hairy (NT) - Monday, Feb 08, 2010 at 18:23
Gday,
As other have said it all depends on who does your inspection, but I have always been under the impression that if they are fitted they have to work.
I would take them out altogether and blank the holes in if you don't think you need them.....no one will probably every know.
403296
Follow Up By: Shaker - Monday, Feb 08, 2010 at 20:51
It would be a lot easier to fit low draw globes, either 5 watt or LED.
672785
Reply By: Coot - Tuesday, Feb 09, 2010 at 14:21
Thanks everyone for your suggestions.I connected the lights today and fiddled with the globes. I can either replace the bullbar lights with 5w ,install LEDs or remove the globes from the vehicle. Either way fixes the problem.
403427
Follow Up By: Lex M (Brisbane) - Tuesday, Feb 09, 2010 at 18:08
"I can either replace the bullbar lights with 5w ,install LEDs or remove the globes from the vehicle."
If the bullbar hides the vehicle lights then you need to put the leds or 5 watt globes in the vehicle lights and leave the bullbar lights standard.
Low power or led globes in the bullbar lights could be dangerous (and illegal).
672925
