Transplanting a 1HZ for a 1HDT
Submitted: Friday, Feb 05, 2010 at 00:10
mahmoud
Does enybody have experience with replacing a 1hz with a 1hd engine in HZJ 78 L-RJMRS , 2001?
Reply By: Mr Pointyhead - Friday, Feb 05, 2010 at 08:44
Look in the lcool forums at www.lcool.org/
forum
There is a number of people there who have done it. They have also done 1HDFTE's as
well
402784
Follow Up By: mahmoud - Friday, Feb 05, 2010 at 19:58
thanks I'll try
672404
Follow Up By: mahmoud - Saturday, Feb 06, 2010 at 10:15
I'm registred there but can not found the Topic, can you help me? (topic, date, author,...). Thanks
672474
Follow Up By: Mr Pointyhead - Saturday, Feb 06, 2010 at 11:17
I know that searching can be a bit difficult on that site. If you are having problems finding what you need, don't be afraid to ask your question in a new thread.
Rob
672479
Reply By: Kanga1 - Friday, Feb 05, 2010 at 14:09
Hi Mahmoud, I believe the factory Turbo 1HD Troopies also have stronger gearboxes and diff/axles fitted to them as
well, to cope with the extra torque. Cheers, Kanga1.
402832
Follow Up By: mahmoud - Friday, Feb 05, 2010 at 20:12
whitch type of gearbox will work propriate and fit to car?, because I can't get in gearbox from 1HD because of gear lever will be too much in front and I have to change axis,cardan,... as
672407
Reply By: Member - ross m (WA) - Friday, Feb 05, 2010 at 19:06
You have to decide which clutch you want to use as the 1HZ clutch is 275mm and the 1HD T is 300mm
There was a way of using a 1HD T clutch on a 1HZ with a H55F gearbox ,but you will have the R151.
The 1HD T will have the H150
402886
Follow Up By: mahmoud - Friday, Feb 05, 2010 at 20:16
I've used clutch from ISUZU N-series truck (it has the same size) and it works very
672411
