Monday, Feb 01, 2010 at 23:54
In answer to your questions.....
1. Updating maps on R66 - yes this is an acknowledged issue - and some thing that does frustrate us all at Hema because we have no control over the update process. As a background R66 obtains street level data from Navteq. Navteq update the data 2 - 4 times a year. Once an update is received then R66 produce a new data set. This updated dataset can be purchased from R66 via the R66sync application (on the CD in the Hema Navigator box). Thus the updated data can take up to 12 months to appear :-( Hopefully you have registered your device at
www.hemavigator.com.au so we can let you know when an update has been made.
2. I have not seen (heard) this before? What application is open when you hear this?
3. We included both OziExplorer and Memory Map on the Hema Navigator so users could access the largest range of 4WD and topographical mapping in Australia. Many users do find Memory Map simpler to use.
John is correct in stating that you can not open a Memory Map file in OziExplorer (or vice versa). That is why we have include the same maps in both Oziexplorer and Memory Map formats on the Hema Navigator (all the Hema maps plus the Geoscience 1:250k).
4. Unfortunately it is not possible to uninstall R66 and install another application.
5. There are many options for installing higher resolutions maps. I would start right hear at ExploreOz -
Digital Mapping - where there is a wide range of products that are suitable for OziExplorer and/or Memory Map.
I hope the helps!
Best regards,
Greg L
671638
