Tuesday, Jan 12, 2010 at 21:42
Meant make of cargo barrier.
It depends whether you are going to mount it behind the front
seat or the back
seat.
The brackets are supposed to be fixed in specific
places in the vehicle.
The bottom ones do NOT cross but go straight back to a specific location.
You usually with a MiIlford drill a 22mm hole and using a supplied wire put the
flange with threads in it inside the roll above the door or window if at the
back you them put screws into it at each end to hold it it place.
You also drill 10mm holes using the plate as a template so you can put the holding screws in
The same with the floor there is a specific pllace to put it and its NOT IN THE BABY CAPSULE BOLT HOLES.
There should be plates that go below the floor with rubber covers to stop
water rusting the bolts.
If you havent got all that or its not a Milford it will be basically the same.
After you get the plates in the big bolts hold the barrier in place by screwing through the centre hole in each plate
The Milford ones have plastic covers to go over the top plates to make them tidy when not using barrier.
Have fun
668066
