1968 FJ40 Shorty - Upgrade recommendation for a little offroading
Submitted: Thursday, Jan 07, 2010 at 19:54
ThreadID: 74971 Views:3547 Replies:3 FollowUps:2
I went out to Dargo with mates for a few days after Xmas and took my truck for my first 4x4 experience. I have nothing to compare it to but I was impressed with how easily she did. I am the third owner and she is for the most part original. I have had the F engine rebuilt, head suited for gas, extractors, LPG system and breaks done.
Not knowing much about what I can/should do with her, I would like to get out for some more 4x4 adventures. Fuel capacity was an issue and lift could have also been a little higher. Without going overboard what should I consider? All advice on what to think about and where to go is appreciated, I live in Melbourne.
Reply By: Willem - Thursday, Jan 07, 2010 at 20:38
Yer forgiven for living in Melbourne :-)
I would keep it as stock standard as possible. Once you start spending on improvements to an older vehicle the ceiling gets higher and higher and the costs can get out of control unless you want them to. Your FJ40 will go anywhere the modern 4bies can go, so stick with the KISS principle.
AnswerID: 398154
Follow Up By: Member - Uncle (NSW) - Thursday, Jan 07, 2010 at 21:29
I agreeImage Could Not Be Found with Willem on this one. We used these vehicles as our mustering buggies in 2008 in Image Could Not Be Foundthe Pilbara, with canvas showing thru on the tyres, wire hanging out as well, and about 25 psi in the tyres. You would be amazed where we took them, no roads to muster on, just all cross country, with a chopper guiding us thru the extremely rough sections and over very bad rocky areas.
A great vehicle, even bog standard!!
cheers Unc
FollowupID: 667008
Follow Up By: Member - William H (WA) - Thursday, Jan 07, 2010 at 23:11
I agree with what Willem has said..........Great tojo and you should keep it stock standard,easy to keep licenced, and parts are easy to get,also they have "NO" computers in them,and all steel from the front to back,if you start to up date them they will cost you heaps, as i have a HJ47 PC and their is no room left under the bonnet.........you will have lots of fun in it and easy to learn the 4WD in it.
Cheers for now...WilliamH...Bunbury...WA.
FollowupID: 667033
Reply By: Geoff (Newcastle, NSW) - Thursday, Jan 07, 2010 at 20:53
I'd blame your parents for the Melbourne bit but you recovered with the FJ40!
Seriously they are a great starter 4wd, nigh on indestructable and loads of fun.
I had one as my first 4wd.
Rather than spend buckets on it view it as a training experience.
The more time you spend in the stock FJ40 the more you learn, if you can shovel it up and down any track in stock form you can do most anything in most any mega buck buggy.
Geoff
Geoff,
Landcruiser HDJ78,
AnswerID: 398157
Reply By: Mikee5 (Logan QLD) - Friday, Jan 08, 2010 at 14:20
Have a look at your spring shackles, they should be almost vertical. If they are pushed out at each end, it means that a leaf spring reset would be a good idea. These old shortys tended to go soft in the springs. A reset will get you a reasonable amount of lift too. Try jacking up one end under the chassis (not the axle), until the spring shackles are vertical - see how much higher the body is. I put Opposite Lock aftermarket leafs in my 1979 troopy, the leafs were longer than standard and better steel, this gave about 1 or 2 inches of lift plus a better ride. You could look at making your own snorkel out of 3 inch exhaust pipe using rubber bends from a truck shop. A mate helped me make one this way. On my 1976 shorty I had a long range tank which sat on the floor under the passenger seat - mine was petrol too - like sitting on a bomb -:)
AnswerID: 398284
